Fuse 19 removed and replaced
Old Sep 15, 2013 | 01:38 AM
sherbercars's Avatar
Default Fuse 19 removed and replaced
with a line fuse and switch. I removed the fuse and replaced it with a blown fuse then I soldered a wire to each side of the fuse and run one one wire to a line fuse and then on to a switch placed in the side of the center consul then from the switch back to the other side of the blown fuse which is then incerted in the fuse box, this way it is protected when the exhaust is turned back on to normal. Buy the way I love the Rap when the exhaust is turned off.but it could be louder. BL.
Attached Thumbnails Fuse 19 removed and replaced-dsc03029.jpg   Fuse 19 removed and replaced-dsc03028.jpg   Fuse 19 removed and replaced-dsc03027.jpg   Fuse 19 removed and replaced-dsc03189.jpg
Old Sep 15, 2013 | 12:56 PM
hawaii's Avatar
Nice job and pics! Must of been scary, just before drilling through the leather huh? I also like the lighted switch.
Old Sep 15, 2013 | 02:16 PM
DGL's Avatar
DGL
On my 2013XKR with performance exhaust when I put the car in "S" with dynamic mode (checkered flag) on the exhaust valves stay open and the sound is so much better than my previous XKR175. No need to remove fuse 19 and install a switch on the MY13. However, nice work.
Old Sep 22, 2013 | 08:40 AM
amcdonal86's Avatar
Try the same thing with Fuse 14 in the driver's footwell. Isn't that for the active suspension control?
I've tried unplugging the fuse between drives and it works to firm up the suspension. However, I'm afraid to wire in a switch and turn the circuit on/off on the fly while driving.
Old Sep 24, 2013 | 03:50 PM
unders's Avatar
If you do pull the fuse though, you can have the exhaust note without the hard ride when in town. I can't see why anyone wants it off. Its only loud with heavy throttle use anyway. Love the way it pops and bangs.
Old Sep 25, 2013 | 09:02 AM
R_Rated's Avatar
Here is another option that requires no cutting and is completely reversible.
Old Sep 25, 2013 | 09:06 AM
R_Rated's Avatar
https://www.jaguarforums.com/forum/x...-valve-102942/
whoops, forgot this...
Old Sep 25, 2013 | 02:50 PM
I totaly agree with you since installed I have not switched it on I would like it even louder, the reason I put the switch in was I did not want to give any excuse for any warranty problems, when taking it in for service I can turn it on , also I wanted the protection of the fuse so I installed the line fuse. BL
Old Sep 27, 2013 | 02:37 PM
BruceTheQuail's Avatar
I'll be getting a MY11 XKR shortly. I'm keen on the louder engine note - I'm made for the V8 noise and prefer it at low speeds which stops me hitting it hard to get the note. Am I just able to pull fuse 19, and leave it out? Sorry, I'm not particularly savvy when it comes to this...
(Later) - ahhh...already answered https://www.jaguarforums.com/forum/s...ad.php?t=87400
Old Sep 27, 2013 | 02:55 PM
amcdonal86's Avatar
We should put a note on the top of each thread that says these workarounds are only for 4.2L X150s!
Lousy 5.0L owners trying to get in on the fun....
Old Sep 27, 2013 | 03:25 PM
Dont feel too bad. I had the paramount exhaust on my 4.2 XF. It sounded awesome, like an Aston. I put it on the 5 litre when I got it, and it didnt sound anywhere near as good. I think that the throb from the 4.2 sounds a bit better, not as tinny as the 5 litre
Old Sep 28, 2013 | 10:49 AM
R_Rated's Avatar
pfffft, worked great for my 5l!
Old Oct 15, 2013 | 09:33 PM
Blueline205's Avatar
Pull fuse 19 = fun sound. Would never have known about this without this thread. Thx.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
jehart49
Sep 12, 2015 05:36 PM
Sprayall
Sep 3, 2015 07:49 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
