Gearbox type
Old Jun 19, 2018 | 05:59 AM
alfapat's Avatar
Default Gearbox type
Trying to establish the code for the gearbox on the Ckr v reg please
vin SAJAC42N01PA21004
i need to replace the sump and it differs from Zak I believe. Thank you
Pat
Old Jun 19, 2018 | 06:15 AM
alfapat's Avatar
Pat
Sorry that’s meant ton XKR and also XK !
Old Jun 19, 2018 | 06:43 AM
Jochem00's Avatar
Welcome,
pans are the same
Old Jun 19, 2018 | 06:55 AM
alfapat's Avatar
Pat
Originally Posted by Jochem00
Welcome,
pans are the same
OK Many thanks are sure about that?
I t was suggested to me it’s a Merc box because of the extra power , just trying to confirm that .
Old Jun 19, 2018 | 08:37 AM
Aonsaithya's Avatar
The X100 XKR had a Merc box, but the X150 had a ZF box in both XK and XKR.
EDIT:
Specifically the 4.0 X100 XK8 had a ZF box, 4.0 X100 XKR had a Merc box, 4.2 X100s have the same ZF box as the 4.2 X150s.
Old Jun 19, 2018 | 09:21 AM
alfapat's Avatar
EDIT:
Thats great thank you , did you use the Vin I put up on the thread to ascertain this ?
Old Jun 19, 2018 | 10:04 AM
Pat
Welcome to the forum alfapat,
I used the VIN to determine that you probaby don't have an X150. The twelfth character in an X150 VIN is always B not A.
I then used the v reg to deduce you have an XKR registered in the UK between 1st September 1999 and 29th February 2000. If so, you have an X100.
Old Jun 19, 2018 | 11:43 AM
alfapat's Avatar
That’s excellent , thanks Graham , I can start searching for this now , it’s the transmission sump and quite difficult to obtain!
Old Jun 19, 2018 | 12:01 PM
Aonsaithya's Avatar
Just Wikipedia, but here's something specifically for the supercharged X100 (as your VIN fits in the range); this is a screenshot from Jag's electronic parts catalogue. Of course, still best to tell your VIN to whoever you're buying the part from and let them verify it.
Old Jun 29, 2018 | 11:10 AM
alfapat's Avatar
that’s great I have now received a new sump as as the old is porous!
one of the securing screws have corroded with the aluminium keepers and sheared off ! Have managed to screw two nuts on it and doesn’t budge. I think the only thing remains is a little heat .....very trick given the amount of oil about , any suggestions please?
Old Jun 30, 2018 | 02:48 PM
alfapat's Avatar
[QUOTE=alfapat;1921234]
Ok to extract the remaining stud fro the transmission sump clamp which snapped off at the head , I used an old exhaust sheid panel to shield heat from the remaining transmission and heated up a doubled nut locked to the thread of the stud briefly , let the heat transfer to the block and after the third attempt slowly withdrew the stud , you have to be careful though! Wish someone would use anti seize when assembling steel next to alloy ! A disaster waiting to happen on older cars !
Old Jun 30, 2018 | 04:16 PM
jagtoes's Avatar
Wow I can't believe the rust/corrosion under there. I assume daily drive and winter too.
Old Jul 1, 2018 | 02:13 AM
alfapat's Avatar
Although it’s a 17 yr old car it is needing to get treatment, it’s not s daily drive and hasn’t been used much in the winter. What your seeing is an old exhaust shield I used to surround the stud for heating the bolt so that the transmission oil left after draining it won’t catch fire !
Does anyone know what the torque settings are for the sump bolts , it’s a Merc box .
Old Jul 1, 2018 | 07:41 AM
jagtoes's Avatar
I'm not looking at the shield but the bracket to the upper right side of the 2nd picture. Last time I saw corrosion like that was on my 2000 chevy plow truck. Just an observation.
Old Jul 1, 2018 | 11:16 AM
alfapat's Avatar
Default Would you know the torque values for the sump pan bolts, please.
no probs that’s the exhaust your seeing then .
Khb1
Mar 6, 2018 03:05 AM
hairbrain
Mar 31, 2009 01:08 PM
riz325
Dec 22, 2008 07:24 PM
ckmk925
Jul 29, 2008 05:30 PM
