Glovebox Has No Catch. Just Drops Open.
Old Sep 19, 2008 | 11:22 AM
lwilliams's Avatar
Default Glovebox Has No Catch. Just Drops Open.
Here's another good one. The glovebox has no gas assist lowering, cable or anything else. When I press the button it just drops like a rock. Any input on this one would be appreciated.
Bill
Old Sep 19, 2008 | 11:41 AM
KAZsam's Avatar
Default RE: Glovebox Has No Catch. Just Drops Open.
Chewing (or bubble) gum, rubber band, spandex, bungie cord
Old Sep 19, 2008 | 01:11 PM
lwilliams's Avatar
haha..Yeah that might work. I would like to know if they all come from factory that way.
Old Sep 20, 2008 | 08:41 PM
GhostriderXKR08's Avatar
If this is any consolation, my SL65 glovebox drops faster than my XKR....LOL.....and the SL65 cost $185K if you buy new.IMO, mine doesn't drop like a rock like you discribed....maybe have it checked.
Old Sep 22, 2008 | 09:35 AM
stevef's Avatar
I checked this morning and the lid drops fairly slowly as if somthing was holding it back.
Next time your in for service have them take a look at it
Old Sep 25, 2008 | 05:12 PM
ScootMan's Avatar
Myglove box dropped fast too....dealer replaced the mechanism.....apparently a plastic piece/hook breaks fairly easy....he said it happens alot.
Old Jun 16, 2012 | 08:59 PM
cpf's Avatar
cpf
Mine drops like a rock.
Old Jun 16, 2012 | 09:09 PM
CleverName's Avatar
Common problem, simple 3$ hardware store fix... Saw it here with pictures... Try to search for the thread....
Vince
Found it---
https://www.jaguarforums.com/forum/x...ove-box-51482/
Old Jun 17, 2012 | 08:10 PM
Gray XK's Avatar
Good to know - mine does the same thing lol
Old Jun 17, 2012 | 10:21 PM
Brutal's Avatar
just remove the glove box and put a small sheetmetal screw though the plastic by the broken hook engaging the cable. FREE or $.10cent fix. And if the cable is broken then crimp an uninsulated ring terminal to the cable and put the screw through the eye. there are several ways to fix
Old Jun 18, 2012 | 10:22 PM
LP30's Avatar
Here's a thread with photos. The Jaguar TSA recommends using a 2mm cotter pin. Simple fix and common problem.
Old Jun 22, 2012 | 03:00 PM
WldCat's Avatar
FWIW there is a TSB on the issue, but the fix via your service dept. is not free:
No. JTB00191
Issue: 1
Date: 17 MAY 2010
SECTION: 501
Glove Compartment Lid not Damped When Opening
CONDITION SUMMARY:
Situation:
The glove compartment lid may not be damped when opening. This may be caused by the glove compartment lid damper cord retaining tab coming away from the glove compartment housing.
NOTE :The split / cotter pin (2mm X 30mm) must be locally sourced.
Action:
In the event of a customer concern of the above, refer to the Repair Procedure outlined below to install a split / cotter pin onto the glove compartment damper arm.
PARTS:
2mm X 30mm split / cotter pin Qty: 1 (to be obtained locally)
TOOLS:
No special tools required
DDW requires the use of causal part numbers. Labor only claims must show the causal part number with a quantity of zero.
Normal warranty policy and procedures apply.
REPAIR PROCEDURE
INSTALL SPLIT / COTTER PIN ONTO GLOVE COMPARTMENT DAMPER ARM
NOTE :Global Technical Reference (GTR) lookup sequence is as follows:
GTR Home> NAS > X150-XK > Service Information > Model Year > Workshop Manual
1. Refer to Workshop Manual (GTR) section 501-12 and remove the glove compartment.
2. Drill a 2mm hole through the glove compartment damper arm (shaded area, Figure 1).
3. Install the glove compartment lid damper cord looped end into the damper arm. ((1) in Figure 2)
4. Install the split / cotter pin into the hole and through the damper cord looped end. (((2) in Figure 2)
5. Fold the protruding ends of the split / cotter pin. (Figure 3)
6. Refer to Workshop Manual (GTR) section 501-12 and install the glove compartment.
Old Jun 25, 2012 | 02:10 AM
dylan72986's Avatar
Thanks for this, I'm taking my car to the dealer to have this fixed as a good will/warranty repair. They fixed cracked chrome trim on the shiftgate surround as a warranty item so I am hoping this will be as well...
No. JTB00191
Issue: 1
Date: 17 MAY 2010
SECTION: 501
CONDITION SUMMARY:
Situation:
Action:
PARTS:
TOOLS:
REPAIR PROCEDURE
Old Jun 26, 2012 | 04:31 PM
WldCat's Avatar
I've been putting off getting my glove box fixed but finally decided to do it this week since the car's in there for other reasons. I don't know if it's because I've continued to operate it since the spring broke or not, but as it turns out, the ENTIRE glove box now needs to be replaced, not just the spring! Apparently the entire hinge is damaged beyond repair. OOPS -- take this as a warning to be very careful with opening and closing your glove box if the spring is gone.
Old Jun 26, 2012 | 06:24 PM
CleverName's Avatar
If it's out of your pocket, I'd ask to see the damage first... Hard to believe it couldn't be fixed...
Your post will prod me to get busy an fix mine ASAP though...thanks!
Vince
Old Jun 26, 2012 | 06:29 PM
WldCat's Avatar
The good news is, Rosenthal never takes advantage of me, so I believe them when they tell me the hinge is broken, but they will probably show it to me just so I can see it myself, which is their MO. In fact, they're trying to find a way to get the part replaced via my extended warranty...
Vince
Old Jun 30, 2012 | 11:45 PM
Big Grey Cat's Avatar
Fixed mine today by using the cotter pin method. Only took about 40 min. to get everything worked out.
Old Jul 16, 2012 | 07:56 PM
Gray XK's Avatar
Dealer fixed mine under warranty in about an hour
Old Jul 16, 2012 | 09:38 PM
tnt10's Avatar
Are you all talking about getting it fixed under the original owners warranty, or the extended Exclusionary warranty?
Curious, as I have such a warranty through 2015.
Thanks!
Old Jul 16, 2012 | 09:58 PM
Gray XK's Avatar
Thanks!
Mine was fixed under the original warranty.
