Headlamp assembly plug removal
Old Oct 16, 2019 | 10:30 PM
MurrayG's Avatar
Default Headlamp assembly plug removal
Quick question if I may. I'm removing my headlamp assembly, but having trouble removing the electrical connector. I am able to twist it clockwise about 1/8 of a turn, and assume it should now pull out - but it does not, and I am reluctant to force it. I checked the service manual and it does not shed any light. I searched these forums for headlamp removal but found nothing about the plug. This makes me think I'm missing something.
Is it simply twist and then wiggle it out?
My apologies if this has been covered and I just missed it.
Thanks all in advance.
Old Oct 16, 2019 | 10:43 PM
TexasTraveler's Avatar
It’s not a twist lock, it has tabs that you must push in and then the plug pulls straight out...
Old Oct 16, 2019 | 11:08 PM
MurrayG's Avatar
This is very helpful - thank you. I see the problem. The tab that is supposed to be on the bottom of the plug is broken off. I hope I haven't hurt the connector by twisting it.
I'll take a look and see if I can figure out how to remove it in the absence of hte tab.
Also - may I ask what manual this image came from? I did not find it in the service manual. Maybe I just missed it?
Thank you so much TT.
Old Oct 16, 2019 | 11:26 PM
Cee Jay's Avatar
I just did all this today. That connector is not a friendly one. A person would think that it would sorta click either on or off, but mine did not. I'd figured out HOW it was supposed to work years ago when I tinted my headlights, but can't for the life of me remember the connectors being as finicky as they were during my bulb replacement.
Oh, and be a bit careful...... the round part where the wired connector clips straight on to IS a twist-to-loosen thing, so it may get wonky. Make sure it's back in place and snug before you reattach the wiring connector.
Old Oct 17, 2019 | 02:39 AM
Originally Posted by MurrayG
..... may I ask what manual this image came from? I did not find it in the service manual. Maybe I just missed it? .....
It's in the Owner's Handbook under bulb replacement. If you don't have a copy, see this thread for a PDF download:
https://www.jaguarforums.com/forum/x...guides-215509/
The original printed documents are available from JLR's printers:
https://www.jaguarlandroverliterature.com/jlr/jaguar/
The website is aimed at Jaguar Dealers but anyone can register and purchase.
Old Oct 17, 2019 | 11:24 AM
MurrayG's Avatar
Ahhh - foolish me. I was looking in the service manual. Thank you!
And once again - this was very helpful. With this I was able to figure out how to use a screwdriver to pull on the remaining part of the broken tab and remove the plug. So once again - thank you!
Thanks you Cee Jay - I will look for that!
King Charles
Feb 15, 2019 07:12 AM
MDsjag
Feb 10, 2019 09:28 AM
WullieJIrvine
Apr 26, 2018 11:10 AM
Darren9090
Dec 15, 2016 08:59 PM
Dr. V12
Aug 13, 2013 07:25 PM
