Help with 2008 XKR Seat release
Old Apr 2, 2014 | 01:38 AM
DaveyD's Avatar
Default Help with 2008 XKR Seat release
Hi, I finally got my 2008 XKR delivered from UK to Brisbane and drove it to Cairns (keep the smirk off!!) now its home I have a problem: the drivers seat recline button jammed in the recline position. I Managed to release the manual seat tilt forward handle and now cannot re-engage the seat tilt catch. The seat motors all seem fine (after I also had to replace a dying battery) The recline motor appears to work but unless the seat tilt catch is caught, I cant prove they are OK. It has been to local Jaguar dealer who says after stripping the seat down; it is broken and need to order a new seat frame (at least thats what I thought he said) I have tried to look for threads on this topic but have had no luck, perhaps its the terminology I am using ??? Has anyone else any experience in this defective part and how I can investigate or fix? Thanks
Old Apr 2, 2014 | 03:08 AM
That's taken some time!
I've moved your question from General Tech Help to XK/XKR forum. Members here with the same model will be able to help.
Old Apr 2, 2014 | 07:14 AM
Ngarara's Avatar
According to the manual, the seat tilt lever pulls a cable attached to a latch lower down on the opposite side of the seat. I can't see an image of the actual latch.
It is possible that the frame is broken; unfortunately, (or, fortunately for me!) I haven't had to deal with any seat issues, so I can't help much.
Old Apr 3, 2014 | 04:58 AM
DaveyD's Avatar
Thanks for the help both the reposting and the answer from Ngarara. Hoping someone may have a seat frame to suit, here in Australia, rather than getting a new one (on back-order from Jaguar UK). cheers.
Old Apr 3, 2014 | 05:16 AM
Ngarara's Avatar
Gotta be a wrecked XK somewhere in Oz
Old Apr 3, 2014 | 05:22 AM
Broken seat frames (the metal) was an issue back in X300 days. Let's hope it hasn't come back to haunt us with XK's.
A Jaguar Dealer will only fit a new frame and not repair one. Repairing something like this isn't the Jaguar way of doing things. No reason why it shouldn't be your way and if they have already told you the cost of a frame, I'm sure you'll agree!
There are few parts available separately for the seat:
The release cables happen to be one the exceptions (items 2 & 3)
If it's only the release mechanism that is at fault, a repair could be possible. More details needed.
Old Apr 4, 2014 | 07:23 AM
DaveyD's Avatar
Hi Graham,thanks for your comments. I don't know if the cable is broken, or the item at the end of the cable which releases or engages the seat-back with the seat itself. Maybe I go back to Jaguar and ask for more info (on monday)Thanks.
GordoCatCar
Jan 2, 2017 01:10 PM
Dz1rfj
Sep 16, 2015 03:44 PM
Clamdigger
Sep 12, 2015 03:43 PM
Super Cat
Sep 9, 2015 03:24 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
