Hesitation when turning right
Old Apr 18, 2023 | 02:57 PM
randyb's Avatar
Default Hesitation when turning right
11 XK NA has a bad hesitation when turning right onto another street when I am at half throttle or more, first 10 feet it takes off like a bullet and then it is like the fuel is cutoff. Will have no throttle response for about 1-2 seconds and then it takes off again. Does not matter what driving mode I am in, same thing. Though it is slightly better in sport mode.
Took to dealer and they say the firmware is up to date and they could not find any problems. Turning left is never an issue.
Old Apr 18, 2023 | 04:04 PM
Cee Jay's Avatar
Sharper right turn means more tire slip, thus initiating Anti-Skid? My anti-skid (traction control) kept going all crazy when I had on a set of Michelin PSS tires, as they were garbage and slipped everywhere.
Old Apr 18, 2023 | 07:57 PM
jahummer's Avatar
Yes even the slightest slip may cut the throttle response.
Old Apr 18, 2023 | 08:27 PM
Brewtech's Avatar
well damn. Im nlw wondering what tires and the condition of his tires are. So shutting off traction control should help reveal if this is what is happening to him.
Old Apr 18, 2023 | 11:27 PM
Cee Jay's Avatar
The FULL shut-off of Traction Control, a ten second hold of the TRAC button. Yes, that'd for sure let that problem known.
Old Apr 19, 2023 | 09:42 AM
randyb's Avatar
Will try holding for 10 seconds, didn't know that little gem.
Old Apr 19, 2023 | 10:03 PM
Brewtech's Avatar
Well?
Old Apr 20, 2023 | 05:06 AM
Brachacz's Avatar
The other way I was on a track and trying to disengage the Traction Control completely but holding Trac DSC did not work for me, I tried to press it for longer and shorter, from Trac DSC activated and deactivate state, nothing worked.
Does that only work in XKR? I've got 2010 XK 5.0
This babysitting was really annoying coming out of corners and when drifting.
Old Apr 20, 2023 | 07:36 AM
Bill400's Avatar
Try using SDD, TorquePro or similar to monitor the fuel rail pressure.
The fuel tank is of the "saddle" design, straddles the drive shaft, etc.
Mechanical fuel pump is in the right lobe/pocket, jet pump is in the left.
Right turns cause fuel migration to the left and vice versa.
If there is a problem with the jet pump, fuel can be isolated in that lobe.
The defect becomes noticable on right turns.
Fuel level on the instrument cluster is average of two senders in the tank.
If left lobe is full and right lobe (with mechanical pump) is empty, about 1/4 full is reported to the IC.
Let us know what you find.
Old Apr 20, 2023 | 12:52 PM
randyb's Avatar
It has a full tank of gas, but will look at fuel pressure.
JamBar
May 3, 2021 01:41 AM
MarkyUK
Oct 24, 2018 03:11 PM
shemp
Aug 29, 2016 12:35 PM
Trakrzy
Oct 29, 2015 06:51 PM
F-typical
Oct 9, 2014 03:26 PM
