homelink button problem
Old Dec 28, 2013 | 07:00 AM
bobdr1's Avatar
Default homelink button problem
My 2010 xk coupe has a broken button on the overhead homelink garage door opener. Spoke with jag dealer, he says that this is part of the mirror system and whole thing needs replaced, asked me about high beem sensors. My rearview mirror has a small dot on it which i assume is autodimmer, my question is from the outside of car, looking at the windshield where mirror is attached, in the middle of the black color on the windshield there is a about a 2 inch square sensor for something, is this for autodimmer headlights or for high beam sensor? thanks
Old Dec 28, 2013 | 09:59 AM
scm's Avatar
scm
I think that square sensor is for the rain-sensing wipers.
Old Dec 29, 2013 | 07:06 AM
bogeymanii's Avatar
Hope it's still under warranty. Had mine replaced(2010xk) at no charge. Invoice was listed at over $800.!
Old Dec 29, 2013 | 08:09 AM
jagtoes's Avatar
I would assume the switch is mounted on a printed circuit board which the dealer would not fix (if possible) but would replace. I would guess it comes as an assembly and they would just pull the old unit off and replace it.
Old Dec 29, 2013 | 10:38 AM
bobdr1's Avatar
Old Dec 29, 2013 | 01:13 PM
Snide72's Avatar
Default Broken HomeLink Button
bobdr1 ... how is your HomeLink button 'broken'? Does it hang down? Does it still work? The left HomeLink button on my 2009 XK Coupe hangs 1/2" lower than the other 2 buttons, but it still operates my garage door. When I'm away from my garage, and I push it up in order to line it up with the other 2 buttons, it just returns to where it started ... 1/2" lower than the other 2! Can I gently pry the 3" x 3" panel off that surrounds the buttons to see why my left button won't stay up like the other 2? If so, any idea on how best to do that? Thanks.
Old Dec 29, 2013 | 05:56 PM
Ngarara's Avatar
The overhead console is a completely separate unit from the mirror, etc. It's held in by 6 clips and has a single cable bundle that connects to the rest of the car. It can be disassembled further to replace the switches, the circuit board, the intrusion sensor or the door-opener module. There are full instructions in the workshop manual.
I think you're being fed a little story by the dealer...
Old Dec 29, 2013 | 08:32 PM
CleverName's Avatar
See attached:
Looks like you need "Item2 - Opener, Garage Door" about $360+
BOL
Vince
File Type: pdf
Old Dec 30, 2013 | 06:23 AM
bobdr1's Avatar
Snide72, yes mine is working just as yours does but is just hanging down 1/2 inch or so loosely, it is under warranty so will get it replaced. I did not understand why whole mirror unit needed replaced either as it looks like homelink is separate item. This is dealer in Orlando, same one that quoted me $299 for an oil change. I have a feeling this place is just trying to ripoff it's customers.
Old Dec 30, 2013 | 07:23 AM
bogeymanii's Avatar
My homelink button hung down exactly as you described. Worked for a while , but then stopped working. I reprogrammed third button until I could get to dealer. Call ahead and schedule service after part available.
Old Dec 31, 2013 | 05:14 PM
bobdr1's Avatar
Just spoke with tampa jag dealer, stated had to see problem before he would order part even though it's 1 1/2 hr drive away for me. Also stated that it may not be under warranty since they may consider it trim item and car was bought used by me! They would have to have it cleared by regional jag rep. I find it amazing this car company with very high end cars treat there customers as second class buyers once the car has been bought!
JarodL
Mar 7, 2024 01:39 AM
Razor
Aug 28, 2019 08:34 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
