How Do I Disable 2007 XKR Antenna? FIXED
Old Dec 31, 2012 | 02:28 PM
Marko's Avatar
Thanks for this, just removed the aerial fuse in literally 3 minutes. Was bugging me for a while. Cheers!
Old Aug 8, 2021 | 03:36 AM
generalcalm's Avatar
Originally Posted by chip
3 min to pull power antenna fuse, look in owners manual , locate 15 amp antenna fuse, (called Ariel) remove center rear upper seat cushion , seat cushion simply pull out one inch, then pull straight up to remove..entire job 3 minutes !
If I am correct, it is actually a 10amp fuse in position f4, behind the rear centre seat.
Old Aug 15, 2021 | 12:25 PM
ericsan's Avatar
Hello to all,
I'm sorry to relaunch this post with a very simple question: do you know where is the antenna of my 2007 XKR? Indeed I don't have a retractable antenna, besides the radio works so badly that we can wonder if they didn't forget the antenna!
Old Aug 15, 2021 | 07:21 PM
Sean W's Avatar
@ericsan your radio antenna is located in the spoiler.
Old Aug 16, 2021 | 01:55 AM
ericsan's Avatar
I will buy and install a big spoiler then to put a big antenna! Thank you very much!
Daytona
E type ( XK-E )
25
Oct 29, 2020 10:45 AM
ziggydrives
Jun 8, 2014 09:49 PM
Crispy
Jan 7, 2012 11:28 AM
rogerdodger
Mar 21, 2011 11:46 PM
guzzi svt
Jun 3, 2010 01:20 AM
