How do you reset the Navigation?
Old Jul 10, 2023 | 01:51 PM
khsjsilver's Avatar
Default How do you reset the Navigation?
I got into my 07 XK the other day and the current location of the car in the Navigation systems is way off. Not just a little, but miles off. So if I try to use the Navigation, the turn by turn is way off. Is there are way to reset the system so it starts with the correct location of the car?
Thanks,
Ken
Old Jul 10, 2023 | 05:20 PM
Hans Amstein's Avatar
In the navigation set-up menu you will find “calibration”, which works fairly intuitively.
Old Jul 11, 2023 | 02:45 AM
Never noticed this. Learn something new every day on the forums.
Here's the relevant section from the Navigation handbook:
Ken's question surprised me as I've never needed to do this even when travelling through Eurotunnel from England to France (30 miles) or Mont Blanc Tunnel (7 miles) from Switzerland to Italy. The navigation has calibrated itself to the new location in a few minutes each time although changing discs is required as UK, France and Italy are spread across three of the four discs in the European set..
Old Jul 11, 2023 | 03:57 AM
RichardS's Avatar
Thanks,
Ken
I suspect that water has corroded your GPS antenna under the rear spoiler and it will no longer be able to determine its correct location. Exactly the same happened to our 2006 XK. I replaced the antenna with a much better modern one which is mounted within the boot and can never suffer the same fate as the original. The total cost of replacement was $25 and it takes about 5 minutes to unplug the old antenna and plug in the new one. I posted the details a year or so ago.
Richard
Old Jul 11, 2023 | 10:31 AM
ram_g's Avatar
Interesting. The antenna fault explanation makes sense. My car was trucked a year ago from Florida to Texas and I never had to re-calibrate the navigation.
Old Jul 11, 2023 | 04:03 PM
khsjsilver's Avatar
I used the recalibration once before when my Nav was a little off. Now, I'm miles off. I will try it again.
Thanks,
Ken
khsjsilver's Avatar
Richard
I will look into this. Thanks!!
Ken
Old Jul 11, 2023 | 05:09 PM
Interesting, I will look into the antenna replacement, too.
Because every once in a while, my navigation system will get lost somehow somewhere - a phenomenon I never had before with any of my cars, including the two prior XKRs.
Locking down the car for a little while will initiate a re-start of the system with the correct location; otherwise I have to “recalibrate”…
Note, however, this is the one and only complaint I might have about my “old” XKR 4.2.
Old Jul 11, 2023 | 09:16 PM
u102768's Avatar
When it plays up have you had a look in the touchscreen 'secret' menu to see what info it has on the satellites, like how many it can see and where it thinks you are?
Old Jul 24, 2023 | 04:46 PM
khsjsilver's Avatar
I found the "Hidden Navigation Menu". See the pic. Since, I'm not connecting to any satellites, does this mean my antena is bad?
Ken
Old Jul 25, 2023 | 12:22 AM
guy's Avatar
guy
You guys inspired me... I have confirmed that the coords on Nav coincide with the coords on my garmin watch.
Thanks for the prod.
Old Jul 25, 2023 | 05:51 AM
kj07xk's Avatar
Ken
Could be. You were outside, open sky, and the car had been running for at least a few minutes?
Old Jul 25, 2023 | 11:33 AM
khsjsilver's Avatar
Yes. Car was running for about 20 minutes. Outside, open sky and I received this reading from several different locations.
Ken
Old Jul 25, 2023 | 12:01 PM
kj07xk's Avatar
Ken
Sounds like the above suggested $25 replacement antenna would be a logical next step.
Old Jul 26, 2023 | 09:46 AM
khsjsilver's Avatar
I have not found any links to where to purchase in the US the replacement antenna as described above. Does anyone know where it can be bought?
Thanks,
Ken
Old Jul 26, 2023 | 10:19 AM
RichardS's Avatar
Thanks,
Ken
This is what the antenna looks like in the UK https://www.ebay.co.uk/itm/223967989828 so it might help you track one down in the US.
The cable you need to connect to the DVD player in the boot is https://www.ebay.co.uk/itm/254151428682
Hope this helps.
Richard
Old Feb 23, 2024 | 11:09 AM
khsjsilver's Avatar
It has taken me a while, but I finally resolved the problem. I replaced the GPS antenna (Part # C2P24351) and the Navigation immediately started working as it should. Attached is a pic of the old antenna. I would add "Resolved" to the title of this thread, but I don't know how to do that.
Thanks for everyone's help!!!
Ken
cpq100
May 16, 2023 09:30 PM
Nookat
Jul 16, 2022 05:50 AM
Pash
US Northeast
Mar 19, 2015 07:59 PM
george37
Oct 1, 2010 05:40 PM
