How to remove the left side light unit
Old Jun 23, 2017 | 01:22 PM
Jagstefano's Avatar
Default How to remove the left side light unit
I want to replace my light unit from my jaguar xk 2006, but I want to be careful to take this out. do anybody know how to remove this left side unit out the car?
Old Jun 23, 2017 | 02:03 PM
Cee Jay's Avatar
Take out the bolts, pull forward a bit, disconnect the harness and the washer line.
That's about it. May want to plug/cap the washer line as it may leak.
Old Jun 23, 2017 | 02:43 PM
Queen and Country's Avatar
I have a followup question:
do you take the light assembly out to change the sidemarker bulbs and such?
does it have to be realigned afterwards?
Old Jun 23, 2017 | 02:45 PM
Ranchero50's Avatar
Ditto, relatively simple job. Three bolts (top inside, top back and in the inner fender), one washer hose quick connect, one electrical connection. Line the opening with some painters tape and wiggle the housing out (worst part).
The X150 service manual has some decent instructions with pictographs showing where the bolt are.
Old Jun 23, 2017 | 02:48 PM
Ranchero50's Avatar
Not really. The housing indexes on the outside by the bolt with the spear and hole arrangement. The inside and top index themselves. It's also pretty easy to adjust the headlamp bulb position on these (think it was a 6mm Allen) through the white button holes on the top back of the housing. There's a plastic tab that sits in the hole to 'blind' them that pops out easily.
Old Jun 23, 2017 | 03:24 PM
GordoCatCar's Avatar
Some of the schematic diagrams from GGG's post on this thread might help: https://www.jaguarforums.com/forum/x...08-xkr-106501/
Old Jun 23, 2017 | 05:35 PM
u102768's Avatar
I changed both of the orange side markers last week after one blew. The headlight can be quite fiddly to navigate completely out but I found that, once all of the bolts were removed and headlamp washer hose disconnected, I could wiggle the light unit forward enough to remove the side marker housing.
I watched my mechanic change one of the other bulbs last year and he had to loosen the bumper slightly to get one of the headlamps back in. I have removed them both previously but it does seem very fiddly and you run the risk of scratching the bumper or dropping the whole unit when it suddenly comes loose!
Old Jun 24, 2017 | 02:56 AM
I always thought having to remove headlamp (and rear lamp) units to change a bulb was ridiculous but at least it's an improvment on the design of the earlier XK8/XKR headlamps which have a serious condensation issue that was never completely resolved by Jaguar.
There's a useful headlamp function for those of us with RHD vehicles going to LHD countries - a lever inside the unit to switch the low beam direction. The headlamp has to be removed and I usually do this in Eurotunnel car park before the Channel crossing. Only takes about five minutes each side but does attract some odd looks from other passengers!
Old Jun 24, 2017 | 04:10 AM
Jagstefano's Avatar
Thank you guys!
for the explanation
Lawrence
XJ40 ( XJ81 )
Jul 25, 2018 03:55 AM
Burnham
Jun 11, 2017 02:44 PM
Poet
Nov 22, 2016 10:33 AM
Joepizzo64
Oct 23, 2016 12:29 PM
dryfjord
Jun 24, 2010 07:47 PM
