Instrument cluster center display Fix needed
Old Sep 20, 2022 | 08:32 PM
MudDog's Avatar
Default Instrument cluster center display Fix needed
I need any advice on how to fix the center display. Its driving me nuts, I cant see anything in daylight, night time is not bad.
Popular Reply
Sep 27, 2022, 01:23 PM
MudDog's Avatar
MudDog
Originally Posted by jahummer
If you consider yourself capable of disassembling the cluster and soldering a new display that’s one solution. The other’s getting a new cluster and either have the main dealer program it or get and learn how to use SDD to program a new one.
Hey Hummer guess what . Its plug and play !!! no soldering needed.
Let me say this.
I have CONFIRMED the statement that you CAN NOT direct swap the instrument cluster. Even if the replacement is in the same VIN Range.
I obtained a nice looking full cluster from a VIN B11xxxx mine is B15xxxx. Direct swapped. Car would not even come on. Swap back, all is fine. WOW.
Im sure somewhere in somebodys mind this makes sense. The BCM and PCM should hold the important info. Why in the world lock out the car with a simple Readout Swap.
Any Way.
After disassembling the donor Cluster , removing the center screen and installing it in my cluster, took 30 minutes. It WORKED I can actually see the Center Screen , Color ME happy.
OLD
NEW
AND YES , the Speedo Needle is 5 mph Off , Ill go In and reset it later. Im just tickled this improvement is off the scale
Old Sep 20, 2022 | 11:52 PM
jahummer's Avatar
Old Sep 21, 2022 | 05:12 PM
Cee Jay's Avatar
That sort of looks like delamination. Maybe take it apart, see if anything is wrong?
Old Sep 21, 2022 | 06:49 PM
MudDog's Avatar
I had a junkyard cluster spotted and was going to get it and do a deep dive, but some rascal in UA bought it right out from under me.
So Im looking for a donor cluster.
Old Sep 21, 2022 | 07:50 PM
Sean W's Avatar
https://www.ebay.com/itm/2007-2009-J...16.m2518.l4276
Old Sep 27, 2022 | 01:23 PM
MudDog's Avatar
Let me say this.
Any Way.
OLD
NEW
Old Sep 27, 2022 | 01:35 PM
McJag222's Avatar
Right on MD.
Old Sep 27, 2022 | 02:06 PM
jahummer's Avatar
Fantastic news and good to know for others who may be in need of this repair, I’ve seen a few displays like yours. And yes the cluster holds critical data for numerous modules in the car.
Old Sep 27, 2022 | 04:13 PM
MudDog's Avatar
Default IAN big Blow
Yes and YOU are In IANs Path , Hunker down or bail , Be Safe
Old Oct 12, 2024 | 04:33 AM
slb07jagxk's Avatar
Default Center Cluster
Does anyone know if you can just get teh center cluster?
Or is it part of the speedo cluster and can be separated?
I need the center cluster and have the same issue with the center touch screen.
Old Oct 12, 2024 | 08:07 AM
Sean W's Avatar
I replied to you other thread entitled "Touch Screen"
https://www.jaguarforums.com/forum/x...1/#post2792747
MudDog
Sep 9, 2022 11:03 PM
ProjektS
Jun 18, 2022 08:22 AM
jacobmstein
Jul 21, 2020 02:32 PM
jinge21
XF (X260)
Jul 22, 2017 02:55 PM
Napster
Oct 15, 2014 01:45 PM
