Intake retrofit in progress for our XKR!
Old Nov 15, 2019 | 08:38 PM
  #61
AlexJag's Avatar
Sponsor
Originally Posted by avos
Really odd, never heard this one that you can't find it, you may have an issue with you IDS setup, its such a standard sensor, its even a available for standard odbII readers.
Maybe I'm being a little slow... I see what you mean but can't find anywhere to log this. Ssd and other adapters all read absolute atmospheric pressure sensor only
Old Nov 17, 2019 | 02:29 PM
  #62
AlexJag's Avatar
Sponsor
Update:. Cel issue resolved! , just needed correct maf screen positioning as well as proper balance of air flow between the two bank...
Old Nov 18, 2019 | 07:48 AM
  #63
SinF's Avatar
Originally Posted by Queen and Country
You should be asking how much restriction is the air filter causing- the answer is nothing in all practicality.
Just pull the filter off, i.e 0% restriction, you car will not suck more air and not produce more power.
Intake restriction is relevant for a naturally aspirated engines. For a forced induction (i.e. supercharger) all your are doing with intake mods is introducing more dust and increasing chances to suck in water going through deep puddles.
What is relevant for forced induction is intake air temperature. If you don't have cold air intake (not sure about XKR, F-type has it) then there are performance gains to be had.
Old Nov 18, 2019 | 08:37 AM
  #64
Ranchero50's Avatar
When I looked at this I was thinking about adding a 1" ID hose from air box to air box to help balance the pressures to the MAF. I also think the larger restriction is where the tubing goes over the valve cover. Using a manual manometer you should be able to probe each tract looking for vacuum measured in inches of water column.
Old Nov 18, 2019 | 12:36 PM
  #65
AlexJag's Avatar
Sponsor
I love when experts chime in😉. Article from Kenne Bell was already posted above , read it ...
And how exactly you figured I would get more dust in using larger size factory filters?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
pk4144
Feb 23, 2021 05:55 PM
VancouverXJ6
Jun 29, 2018 09:55 AM
trosty
Oct 21, 2013 04:37 PM
azeteg
Mar 8, 2013 10:31 AM
bgilgall
Mar 8, 2010 08:28 AM
