Interesting observation on 5.0L oil cooler
Old Jun 26, 2014 | 07:21 AM
jagtoes's Avatar
Default Interesting observation on 5.0L oil cooler
I had the car on the lift yesterday and while looking around I noticed looking into the lower grill how the oil cooler is mounted. Instead of being mounted vertical it is mounted horizontal. It runs the full length of the lower grill and it has a plastic deflector mounted on top to direct the airflow down. If you look under the nose you will see louvers where the air is expelled from the cooler. On most applications I have seen the cooler is usually vertical where the air flow is straight through the front.
Old Jun 26, 2014 | 06:21 PM
Ngarara's Avatar
Hang on - the oil cooler sits in the V of the engine block, and is fed with cooled water from the main radiator (it's probably better described as a heat exchanger). What you've described is the auxiliary radiator, only fitted to the XKR:
The auxiliary radiator is connected in parallel with the (main) radiator to increase the engine cooling capacity on SC vehicles. The auxiliary radiator is mounted horizontally in an air deflector attached to the front of the charge air radiator. The two end tanks of the auxiliary radiator incorporate connections for the supply and return hoses that connect it to the main radiator.
Old Jun 26, 2014 | 07:23 PM
DGL's Avatar
DGL
Diagrams from shop Manual:
Attached Thumbnails Interesting observation on 5.0L oil cooler-oil-cooler1.png   Interesting observation on 5.0L oil cooler-oil-cooler.jpg   Interesting observation on 5.0L oil cooler-oil-cooler2.png   Interesting observation on 5.0L oil cooler-oil-cooler4.png
Old Jun 26, 2014 | 09:56 PM
jagtoes's Avatar
OK I stand corrected and Thanks.
Old Jun 27, 2014 | 12:26 AM
Ngarara's Avatar
No prob - thanks for making me investigate it, since I wasn't aware of it either!
Old Jun 27, 2014 | 08:21 AM
DGL's Avatar
DGL
No correction intended. I'm glad you bought this subject up. Who would think the 5L SC had an internal engine oil cooler. My GT-R and Merc AMG both have external conventional direct air coolers which IMO would be more effective and safe.
In another diagram in the shop manual it shows a separate line coming from the water pump going to the oil cooler after the water was cooled from the radiator. Our water pumps are also known to have been revised several times because of a design defect. This may add significantly to an engine overheating rapidly when a warning message appears "over heating". I would take any warning message about overheating very seriously with this design.
Old Jun 27, 2014 | 08:25 AM
jagtoes's Avatar
Originally Posted by DGL
No correction intended. I'm glad you bought this subject up. Who would think the 5L SC had an internal engine oil cooler. My GT-Rs and Merc AMG both have external conventional direct air coolers which IMO would be more effective and safe.
In another diagram in the shop manual it shows a separate line coming from the water pump going to the oil cooler after the water was cooled from the radiator. Our water pumps are also known to have been revised several times because of a design defect. This may add significantly to an engine overheating rapidly when a warning message appears "over heating". I would take any warning message about overheating very seriously.
I recall when doing a V8 conversion on my 76 XJS I removed a large oil cooler from in front of the engine. I didn't use one on the V8 so I must have kept this cooler for maybe 10 years before I junked it. I couldn't sell it at the time. This is a 1st for me as I have never seen an internal oil cooler . Live and learn.
Old Jun 27, 2014 | 09:14 AM
DGL's Avatar
DGL
Picture of water pump with separate outlet to oil cooler. If this fails everything will heat up super quick. DO NOT IGNORE "OVER HEATING" WARNING! Jaguar should, also, release a bulletin to owners to not ignore "over heating" warning if they are not going to recall the defective pump.
It's no secret the original water pump is defective and will fail. Some members have lost their engines from over heating. The water pump is obviously a critical component to safe guard the 5L engine because it feeds the engine and oil cooler. IMO Jaguar should recall cars manufactured with the defective water pump and have the new designed water pump installed. I will surely install the new water pump on my XKR if I still have it when it goes out of warranty. It's not really a big job and can save your engine.
Attached Thumbnails Interesting observation on 5.0L oil cooler-water-pump.jpg
Old Jun 27, 2014 | 02:52 PM
old_dawg's Avatar
Is this oil cooler just on the 5.0L or also on the 4.2L?
I lost my 911 due to a problem with a similar type oil cooler. I found out that Porsche engines don't run well when the oil and coolant mix
Old Jun 27, 2014 | 06:06 PM
Ngarara's Avatar
No, the 4.2 has 1 or 2 conventional radiator-style coolers at the front. Not quite sure which models/years have which - the manual is confusing, as it suggests an XKR has either 1 or 2 and the XK has none. My guess would be: XK has 1, XKR has 2.
Old Jun 27, 2014 | 07:36 PM
u102768's Avatar
These are the options from the parts manual. On the 4.2L XK the oil filter seems to screw straight on to the cooler.
Attached Thumbnails Interesting observation on 5.0L oil cooler-oilcoolers.jpg
Old Jun 28, 2014 | 05:07 AM
Ngarara's Avatar
Wonder when they changed the XKR from one to two - and why. Or perhaps it's a market thing; maybe cars sold in hot places have two.
Old Aug 24, 2014 | 12:46 PM
GrtShrk's Avatar
Is there an online location to view the PDF shop manual and parts manual that are referenced in this post? Thanks for any assistance!
Bob
Old Aug 24, 2014 | 02:27 PM
Ngarara's Avatar
I bought mine off eBay, but apparently most of those are bootlegs of one of the forum member's work:
Jaguar XK XKR X150 Workshop Manual
Old Aug 24, 2014 | 09:43 PM
ccfulton's Avatar
An oil to water cooler located under the supercharger. Well, that has to be one of the more complicated solutions to a simple problem that I have run across.
Learn something every day.
Old Aug 25, 2014 | 05:06 AM
plums's Avatar
The airflow transition for the auxillary radiator is an interesting turn of logic. It would keep the exhausted air from continuuing on through the main radiator.
As for hiding the oil heat exchanger under the SC, they obviously wanted something else to inconvenience diy'ers besides the infamous hoses under the SC.
Old May 2, 2019 | 02:02 PM
pauledddy's Avatar
Is there any way to run a conventional air to air oil cooler? Driving round the nurburgring and i was hitting 130°c oil temps, and would like to find a way of stopping that!!
Old May 3, 2019 | 02:04 PM
Ngarara's Avatar
Not sure where you'd hide it - there's not a lot of unoccupied space with access to frontal airflow.
Old May 3, 2019 | 02:54 PM
Queen and Country's Avatar
Would a heatsink on the oilpan make sense? (where it would protrude from a cutout in the liner)
Or would there be not enough ground clearance?
Old May 21, 2023 | 01:43 AM
sweeper's Avatar
this is nothing new, to aid quick warm up times the oil is firstly heated by the coolant, once up to temp the oil is cooled by the coolant, so it’s not just an oil cooler! Works well until failure fills the cooling system with oil! Like mine which is broken down miles from home on a weekend away! Recovery home tomorrow.
