Intermittent roof issues
Old Nov 9, 2022 | 03:19 PM
tommytarget's Avatar
Originally Posted by guy
As others have stated these are typically symptoms of insufficient voltage or current.
This is another situation where there is a lack of empirical data. And so it is difficult to help you.
What battery size? Rated for how much CCA? What is the charge of the battery when cold, in the morning? (And the car NOT running!)
Do you have additional electrical systems plugged in?
We with experience have learned to check the electric system first.
Additionally, there are pin point tests listed in the workshop manual.
we had previously done battery tests but it wont hurt to have another look and also collect the data you mention
Old Sep 5, 2023 | 04:02 PM
so the problem is getting worse. the previous solution of waiting a couple mins does not work reliably. i have to cycle the roof multiple times ... eventually i get lucky but i suspect my luck will run out soon.
I took the car into my local jag shop (who i like). battery tested out fine.
this was the result of their investigation."We scanned vehicle and found various codes that can be found in the inspection for the folding top. We removed the rear seats to
access look at wires and sensors. We did not see any chafing or cut wires on any of the sensors. We put the top into service
position to look at the sensors along the b pillars all wires looked to be in the proper position. The next step would be to access the
folding top module to Ohm out sensors for the window regulators, trunk position sensor and hood down switch. we do not have
access to the values of the sensors so we cannot do anything at this time. We did fnd some mold along the top hinges seen in the
inspection pictures. We cleaned off, and cleared out the drains.
The latch motor is loud and struggles to open and close. At this time we suggest that the vehicle be brought to a Jaguar dealer for
further diagnosis and repairs."
The following codes showed up on some tests
  • B1067-13 Intermittent Trunk position sensor
  • B107A-23 Intermittent Hood Down Switch
  • B107C-11 Intermittent Hood rear quarter motor
On other tests additional codes appeared
  • B1076-31 Intermittent Front latch open sensor *
  • B107A-23 PERMANENT Hood Down Switch **
  • B107E-11 Intermittent Convertible top lid compartment cover valve 1 *
* new code
** changed from intermittent to permanent
searching the internet i see these explanations of a couple of the error codes.
B107C11 Convertible top rear quarter motor
  • Convertible top rear quarter motor circuit - short to ground
  • Refer to the appropriate system wiring diagram article and test convertible top rear quarter motor circuit for short to ground
B107631 Front latch open sensor
  • No signal
  • Carry out any pinpoint tests associated with this DTC using the manufacturer approved diagnostic system
So what does this all mean? I dunno. so before i take it to a Jag dealer we might try one experiment to replace the front latch sensor (waiting for a quote on that before proceeding).
thoughts?
Old Sep 5, 2023 | 04:20 PM
twhumphrey's Avatar
I think the latch sensor wire harness is your problem. See my post at:
https://www.jaguarforums.com/forum/s...errerid=168203
Old Sep 5, 2023 | 04:25 PM
cool thanks. will check that out!!!
Old Sep 5, 2023 | 06:07 PM
Spitjag's Avatar
Hi, I had a similar problem and it was the latch motor. The plastic worm and wheel in the gearbox was worn and struggled to drive the latches to the locked position, I would get a top not latched message and the windows wouldn't roll up. I purchased a new worm and wheel assembly in brass from Amazon (its the same assembly as used on the BMW E46) it took 10 mins to fit as all has been fine. The gearbox/motor is now much louder with the brass worm and wheel but hopefully a bit stronger.
Old Sep 6, 2023 | 06:50 AM
XJFanMatt's Avatar
Originally Posted by tommytarget
thanks. have tried all the suggestions. the only thing that seems to work is to wait some time after parking before attempting to raise the top. after a long drive yesterday the roof ( and quarter windows ) came up perfectly after only waiting 15 min
Hello Tommy, I am thinking I have the same problem, after waiting are you stating this car and putting up the top to get the windows to work or putting this top up without starting. I would assume it is running because the top is a big drag on the battery.
Sorry I didn't read the whole thread before I replied I am going to check the wires on mine also.
Old Sep 6, 2023 | 07:19 AM
thanks ... will check that out too.
Old Sep 6, 2023 | 07:20 AM
  #28
i always performing roof operations with the car running.
Molineux
Apr 18, 2025 07:38 AM
XCrossWindsX
Nov 10, 2015 04:10 PM
tberry6686
Jan 11, 2014 09:04 AM
LuvMyKitty
Aug 29, 2012 06:18 PM
o2manyfish
Apr 29, 2011 06:00 AM
