Iridium Spark plugs
Old May 10, 2019 | 12:41 PM
badicedog's Avatar
Default Iridium Spark plugs
Good morning guys, I'm doing an oil change today. 2009 XK, 21k miles now, been enjoying the hell out of it. It got me thinking.... car is extremely well taken care of BUT nevertheless it's a 10 year old car. I was going to change out the plugs with Iridium ones since they seem to be the best ones out there at the moment. Anyone know what type of factory plugs came in 2009? Any other fluids that I should be concerned with since the car is 10 years old? Thanks for you advice and patience with all my questions.
Old May 10, 2019 | 01:31 PM
JackJohn's Avatar
Brake fluid; transmission; differential; power steering I looked through the manual but didn't find a spark plug spec. It's probably there, I just couldn't find it.
Old May 10, 2019 | 01:44 PM
badicedog's Avatar
I also looked through the manual, couldn’t find it either. Thx for the response
Old May 10, 2019 | 01:56 PM
jahummer's Avatar
NGK IFR7N
EDIT: actually They are IFR5N but the 7N is a bit colder and what was spec’d for the Aston version as well Middle East delivered cars due to the hot climate.
Old May 10, 2019 | 03:41 PM
gkubrak's Avatar
Here's an OEM one and the specs.
Old May 10, 2019 | 04:26 PM
pwpacp's Avatar
Plugs are not time sensitive parts so why the change at 21K when they should be fine through to 100K? Are you experiencing thrown codes or deteriorated performance?
Old May 10, 2019 | 05:19 PM
Tervuren's Avatar
I must admit, I enjoy taking things apart and putting them back together on my Porsche.
Might possibly be similar, just doing it to enjoy the car even more.
Old May 10, 2019 | 05:55 PM
badicedog's Avatar
The car stalled out on me last week from a cold start for no particular reason that I can tell. Would idle low, below 500 RPM then die. Did this for 3 times. No codes what so ever.
Old May 10, 2019 | 06:26 PM
NBCat's Avatar
May be a good idea to check the fuel pressure and compare it to the Workshop Manual specifications. If the pressure appears low, try changing the fuel filter first as the vehicle is ten years old.
Old May 10, 2019 | 10:11 PM
Tervuren's Avatar
I agree with NBCat.
I had problems where my XK would die trying to start, or start rough.
Issue was fuel filter.
Old May 11, 2019 | 12:51 PM
badicedog's Avatar
I’ll look into the fuel filter. Hadn’t occurred to me since the vehicle has such low mileage.
Old May 11, 2019 | 12:52 PM
badicedog's Avatar
I agree with NBCat.
What was the repair cost on the fuel filter? Thx
Old May 16, 2019 | 01:17 AM
MarkyUK's Avatar
Here's the plugs I was recommended by my Indy for my 2014, a set 8 were £50/$60 inc shipping.
Old May 16, 2019 | 11:50 AM
110reef's Avatar
All it takes is one bad tank of gas to clog a fuel filter.
Old May 17, 2019 | 05:52 AM
Tervuren's Avatar
I do not remember.
I haven't been counting money spent with this car.
I believe with labor it was <$300, but whether that Less Than was $50, $200, or $299 I do not recall.
That was three years ago as well. Prices tend to go up.
David's XKR
May 15, 2017 04:45 PM
Ilja Oblomow
Apr 8, 2013 08:13 AM
Mr. Fox
Jan 21, 2011 03:23 PM
jag79
20
Aug 11, 2010 08:52 AM
BlackJack
Feb 4, 2010 11:48 AM
