Jump Starting a 2013 XKR
Old Jul 31, 2018 | 07:22 AM
drbbop's Avatar
Default Jump Starting a 2013 XKR
I have not had a problem yet, but if I ever had to jump start my car, what is the procedure?
As I look in the trunk, I do see one terminal on the drivers side of the car, but appears to be a negative pole as
it is black. Where is the positive pole or is that it?
Old Jul 31, 2018 | 07:49 AM
TexasTraveler's Avatar
Actually that is the positive +, you can use one of the threaded post down in the spare tire storage for a negative -
Old Jul 31, 2018 | 07:51 AM
pwpacp's Avatar
The positive terminal is the one with the black rubber boot over it......you can see it is insulated from the body. If I'm not mistaken the negative terminal in the spare tire well. It is advisable to not have the donor vehicle running so you are just using its battery for the jump. Once your XK is started disconnect the jumpers right away (neg first).
Old Jul 31, 2018 | 10:22 AM
From a TOP SECRET Jaguar document only available to those who open the glove compartment
Old Jul 31, 2018 | 01:30 PM
kj07xk's Avatar
Now that I've read it, I need to burn this thread... stand back!
Gilstan
Mar 29, 2017 07:48 AM
kbernal1016
Sep 15, 2012 02:15 AM
Boeingtravel95
Aug 11, 2012 08:40 AM
xjr4life
Apr 16, 2010 06:57 AM
harounq21
Jun 19, 2008 06:12 PM
