Leaky car?
Old Apr 7, 2018 | 11:44 AM
HelenIsaac's Avatar
Default Leaky car?
The carpet is soaking behind the driver seat and I don't know why or where to start looking
Old Apr 7, 2018 | 11:47 AM
DevonDavid's Avatar
Coupe or convertible ?
What year ?
Old Apr 8, 2018 | 04:17 AM
HelenIsaac's Avatar
It's a 2010 coupe
Old Apr 8, 2018 | 06:04 AM
DevonDavid's Avatar
With an earlier car, I would suggest looking at the "seal" where the driver's side window meets the rear "quarter" window to see if there's a gap through which rain might be seeping. As we know, there's been a lot of rain the UK over the past couple of months.
But - not sure if the design of yours would be the same as the earlier model X100s.
Old Apr 8, 2018 | 06:55 AM
Welcome to the forum Helen,
I've moved your post to correct section.
Please post an intro in the new members section when you can.
Old Apr 9, 2018 | 05:01 AM
HelenIsaac's Avatar
If it was leaking through the window or seal, wouldn't the inside of the door be wet too?
Old Apr 9, 2018 | 09:33 AM
Stuart S's Avatar
Helen,
If you can't find the source, this company is in London and should be able to help:
https://cars.newagain.co.uk/car-water-leak.asp
You can also Google "smoke test for car water leak" for more advice.
Good luck, and please keep us updated.
Stuart
Old Apr 9, 2018 | 11:13 AM
kj07xk's Avatar
Not if it was running down behind the interior panel.
Take out the back seat and see if there is any wetness under it.
Old Apr 9, 2018 | 11:37 AM
Ridicrick's Avatar
Same as me, 2007 coupe... completely soaked behind drivers seat, about 1/8" puddle of water and rusty seat belt mounts. After removing carpet I couldn't find the source but I ended up sealing everything I could, every little dam spot where I thought water could come through. But none of that will matter if its somehow coming from above and draining down.
Old Apr 9, 2018 | 12:51 PM
jagtoes's Avatar
So is this a coupe only problem or has anyone with a convert had the same issue.
Old Apr 9, 2018 | 01:32 PM
110reef's Avatar
My convertible has had some wetness in the trunk area. I have not tracked it down, but I have not really tried either. Plus my car has been hit in the rear which could potentially be the cause, though the repair job was excellent.
Old Apr 9, 2018 | 01:34 PM
110reef's Avatar
In my BMW, there were drain ports in various locations that would clog with leaves or pine-needles or other obstruction, and that would cause puddles in some areas until you unplugged the correct drain point. Perhaps that is the problem with the coupes.
Old Apr 10, 2018 | 10:55 AM
makecopies's Avatar
Sometimes my drivers side seat belt is moist after a hard rain. So I know I have a leak somewhere also.
Old Apr 10, 2018 | 12:02 PM
Cee Jay's Avatar
I concur with the Smoke Test. Most auto shops can do this, and the equipment is not expensive which means the test in cheap. Cost maybe $50 tops to find a leak.
Old Apr 18, 2018 | 09:32 PM
amcdonal86's Avatar
COuld this not be related to the HVAC drain duckbill being clogged? In the UK the drivers seat is on the right.
JimC64
Sep 22, 2025 02:52 PM
Drossvet
Oct 21, 2016 09:27 AM
Shearwig
Oct 4, 2016 11:32 AM
Ubad2
Oct 3, 2016 04:22 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
