Lost 53 pounds today...lithium conversion success!
Old Aug 5, 2021 | 01:11 PM
AlexJag's Avatar
Sponsor
Originally Posted by jahummer
Follow up to report how fantastic this battery is. Has not been on the CTEK since fitted. Driven rarely and for short distances only until track season resumes later this year. Battery at full charge, all electrics operating correctly, wish I'd done this years ago. Certainly appears significantly more reliable than even AGM.
I'm tempted to try this on my xkr which is driven a few times a week. My main concern is that can it handle cooling fan on, and other electronics driving through traffic.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Aug 5, 2021 | 02:53 PM
jahummer's Avatar
No issues whatsoever, even with headlamps on and playing music at high volume, no indication of interior filament lamps dimming or flickering either. When I spoke with AntiGravity support, he explained, like lithium batteries used in other daily used devices, their behavior is just quite different, it's apple to oranges so to speak so you can't rely on comparing things like amp hours. Lithium offers more stable and reliable power than lead acid BUT with this size battery, you will not get the long running time with alternator not running as you would with a full size lead or lithium battery, likely about 20 minutes on this one compared to perhaps an hour with a well sorted lead or full size lithium.
Old Aug 5, 2021 | 09:31 PM
Cee Jay's Avatar
Well, since supposedly the battery is used for ONLY starting the vehicle (yeah), any battery capable of doing that SHOULD suffice as the alternator is supposed to be capable of running everything PLUS charging the battery...... so........ again supposedly any battery powerful enough to start would be good.
Old Aug 6, 2021 | 08:40 AM
Samets's Avatar
Doesn't look like they support a direct replacement for our cars.
Old Aug 6, 2021 | 10:04 AM
jons's Avatar
that's just their database being incomplete. to the best of my knowledge we all have an H8/L5/49 battery. https://antigravitybatteries.com/pro...tive/ag-h8-rs/
you can use anything you like so long as its built for the correct voltage, rated for enough current to crank the car, and bolts down tight with whatever bracketry you've got or choose to make. a comparable AGM: https://www.rockauto.com/en/moreinfo...t=2476&jsn=824
Old Aug 6, 2021 | 10:27 AM
Samets's Avatar
I know. I was just taking a jab at them. Something to look forward to when my battery dies...
cat_as_trophy
Nov 29, 2025 11:08 AM
twoblackjags
Mar 19, 2024 06:41 AM
Camgear
Sep 2, 2023 12:01 PM
Tcasmarcus
Mar 19, 2017 02:51 PM
vicsrc
Mar 8, 2014 04:25 PM
