Lumbar Support Deflating
Old Sep 15, 2023 | 09:15 PM
Jaaaaaaaaaaag's Avatar
Default Lumbar Support Deflating
Haven’t tested the passenger side, but the lumbar support is deflating slowly pretty much right after I inflate it all the way or inflate it at all. It doesn’t deflate entirely unless I adjust it to minimal inflation. It deflates within 30 seconds or so after I inflate it. Also the memory setting to recall my preference of it inflating does nothing. Any thoughts? I feel like if it was just a leak, then it wouldn’t also be not recalling it to inflate. It does inflate all the way if I do it manually with the adjuster. But it won’t stay inflated. I haven’t tried the side bolsters but I think they have stayed. Everything else works on the seat.
Old Sep 16, 2023 | 11:29 AM
bgpenguin21's Avatar
Spitballing... Almost sounds like the memory setting for that lumbar specifically is saved in that low-deflate position. And it's just constantly triggering the memory. Maybe try inflating it and then saving to a different memory profile (maybe Profile 3, for example)? If that doesn't work, I wonder if a hard reset of the electrical system, then resetting the seat memory positions to a fresh profile would work? I agree that it doesn't sound like a leak, with everything you described.
Old Sep 16, 2023 | 11:30 AM
justinhill's Avatar
But if it was a leak, the memory would think it was still inflated and would take no action...?
Old Sep 16, 2023 | 02:23 PM
Sorry if I wrote my response in a confusing way. What I'm saying is maybe the memory value for the lumbar is actually stuck at a lower setting, and for some reason the "activate" memory function just keeps triggering. Bottom line: the details from the original post seem like an electrical issue related to the seat settings or memory settings, as opposed to a leak. The original post says that the lumbar bladder doesn't seem to deflate completely. Seems like it would if there were a leak.
All that said, I've never opened up the seat to look at the components like the lumbar bladder, so maybe there is a mechanical reason at the heart of things.
Old Sep 16, 2023 | 02:47 PM
correct. I appreciate you’re suggestion tips and am going to try them. Yes it’s basically like if 3/3 was entirely inflated (about to burst) and 0/3 was completely deflated like your lumbar is hunch-backing and getting sucked into the seat almost, mine seems to go to a solid 1/3 and remain there for good. If I then go and try to deflate it further, I will hear that hissing noise and the lumbar will go all the way to 0/3.
Old Sep 16, 2023 | 02:51 PM
If there's anything I've learned in the short time that I've been on this forum, it's that these cars are overall mechanically reliable if you take care of them. Buuuuuut... they also seem to have a good number of electrical gremlins that manifest themselves in some crazy ways.
Update us on what you discover.
Old Sep 16, 2023 | 03:16 PM
Will do thank you. Yup I did some research before getting one, and that’s exactly what the general consensus seemed to be regarding mechanical vs random electrical reliability haha.
Old Sep 18, 2023 | 11:00 AM
dynamohm's Avatar
Im not sure how the Jaguar system works but on my Mercedes if the ecu picks up that the pump is running too long due to a leak, it will shut the pump off until the next key cycle .
Old Sep 18, 2023 | 04:52 PM
Sean W's Avatar
OK everyone stop saying leak and bladder.....
Old Sep 18, 2023 | 05:52 PM
Cee Jay's Avatar
I had a stent from my kidneys to my bladder. Does that count? It was to get the backed-up infected kidney juice out of my ureter.
mohaqq
Sep 18, 2021 12:55 PM
04xtype04
Feb 6, 2014 02:24 PM
Sergius
Mar 26, 2013 08:49 PM
relinuca
Nov 14, 2010 08:08 AM
rstallard
Apr 26, 2010 07:21 PM
