Mystery Bracket (Attached to Frame Cross Member near Steering Rack)
Old May 12, 2012 | 05:04 PM
emxnyc's Avatar
Default Mystery Bracket (Attached to Frame Cross Member near Steering Rack)
I'm messin' with brakes today, and this is the first time I've lifted her snout--so this is all new to me. (Looks a bit different than the X-Type...)
I noticed a small bracket--no more than 3" in length--attached to the front cross member, near the steering rack. It looks slightly bent, and you can clearly see that there is a bolt threaded into it. I wondered if the top bolt loosened, allowing it to swing down like that, but there is a bent tab at the top which aligns with a hole in the member--so it appears that it's supposed to be positioned this way.
Anyone know what this is for? Is something missing? The odd thing is that if this were straightened and pointed downward like this it would actually be the lowest point on the entire frame.
I'm under the car all day and evening. Any quick help would be greatly appreciated!
-e
Old May 12, 2012 | 06:42 PM
CleverName's Avatar
Maybe the bracket used to hold the underside engine cover on?
Vince
Old May 13, 2012 | 10:04 AM
britannia's Avatar
Good question! Will take a look next time I'm under the Cat............
Adrian, 2007 XK Coupe
Old May 13, 2012 | 11:01 AM
emxnyc's Avatar
Vince
Thanks for the diagram! My engine tray is in-tact; this bracket is quite a distance from it as well. I'm wondering if it held the headlight fluid reservoir--or perhaps an exhaust bearing...
I may just remove it. Hopefully Jag won't ****** away the balance of my warranty.
e
dsnyder586
Dec 29, 2024 07:39 PM
rusty37
Apr 5, 2020 07:40 PM
sogood
Sep 15, 2015 07:35 AM
Richard_gib
Sep 12, 2015 07:08 PM
Dallas XK8
Sep 3, 2015 12:17 PM
