Nasty Noises XKR. Mirrors wont fold back
Old Mar 10, 2022 | 01:31 AM
Spitjag's Avatar
Default Nasty Noises XKR. Mirrors wont fold back
Trying to get to grips with my new to me XKR and apart from the occasional complete failure to get the ignition up there are a couple of other issues I could do with some help with.
I know its a 1st world problem but often the indicator ticking sound sounds very harsh and metallic as does the door open chime as if the speaker that produces the sound is damaged, other times it sounds perfectly normal, is the sound generated at the instrument cluster or is there a separate sounder somewhere?
Another irritating problem is the left hand mirror doesn't return back to the driving position all the way after being folded in. It always moves and doesn't make any undue noises but requires physically moving to the proper position. Is there a limit switch or sensor that can be adjusted or maybe a repair kit to replace the drive internals.
I appreciate these are very minor issues but it make my OCD tingle. Ha
Many Thanks
Old Mar 10, 2022 | 03:24 PM
Bill400's Avatar
Sounder: on rear of Instrument cluster circuit board, within the IP housing.
I wonder if it too could be affected by the Midlands high humidity/possible corrosion?
Mirror: Remove the plastic cover (its press fit). Clean and lubricate as appropriate.
Please post what you find.
best regards,
Bill
Old Mar 10, 2022 | 03:52 PM
MarkyUK's Avatar
It;s a 16yr old car and the first year of production, learn to live with it or be prepared to spend a few £££'s
You gets what you pay for
Old Mar 10, 2022 | 05:00 PM
Barry Leftwich's Avatar
i don't think the folding in mirror models are that old.I know my 2007 XKR didn't have folding mirrors on it
Old Mar 10, 2022 | 06:06 PM
u102768's Avatar
That is probably because they were an option initially. My 07 had them and I think they became standard in 08.
Old Mar 11, 2022 | 10:25 AM
Bill400's Avatar
The latest production X150 is now eight years old. The model is in transition from "Modern" to "Classic".
However, the technology of the IP sounder and folding mirrors is unchanged through the current models.
Disassembly, cleaning and lubrication will likely return their function "as new".
We enthusiasts must have "deep pockets", must be or become competent techs or sadly, become former owners.
So, welcome new XK owners. Help us keep the model alive and supported by JLR and after-market vendors!
Old Mar 12, 2022 | 03:19 AM
Originally Posted by Spitjag
..... Another irritating problem is the left hand mirror doesn't return back to the driving position all the way after being folded in. It always moves and doesn't make any undue noises but requires physically moving to the proper position. Is there a limit switch or sensor that can be adjusted or maybe a repair kit to replace the drive internals. .....
The mirror head is designed to fold on impact to avoid it being destroyed. When this happens, the fold motor drive 'peg' pops out of the locating hole and the mirror head goes into the folded position. The Owner's Handbook gives the procedure for re-engaging it BUT this doesn't always work!
When the drive peg doesn't re-engage in the hole, the mirror head will move when powered but NOT to the correct position. To resolve this, power unfold then manually move the mirror head in and out until you feel it pop back into the drive. Often it has to be moved beyond the normal unfolded position for this to happen but it's obvious by feel when it clicks into place.
Old Mar 12, 2022 | 10:12 AM
No Quarter's Avatar
I put some sealer in the "loudspeaker" at the back of the gaugepanel, also like you wanted a lower volume
Old Sep 15, 2023 | 10:44 AM
ynotfl62's Avatar
This is the first sage advice I've read for the power folding mirror not closing/opening to the correct position. I tried this and you definitely have to "unfold" the mirror more forward to get it to pop back into the drive as you fold it back in. Unfortunately, this did not work.
My issue is that the passenger side mirror folds in TOO far and nudges the window glass. Compared to the driver's side, it folds in over 1.5 inches too far. When it unfolds, it does lock to the proper position. The real issue is when you put the window down when the mirrors are folded in and then put it back up. The mirror kicks in a bit further without the window blocking it. And the windows going down and then up happens automatically when you put the convertible top down and up on an '06. My '01 does not automatically roll the windows down when putting the top down and does not automatically roll them up when putting the top up.
So, when the window goes up it catches the mirror and then you do get a loud POP! Parking then becomes a matter of always folding in the mirrors absolutely as the last step!
I am not the first owner and the car has had this issue since I bought it back in 2014. It has been a few years since I've forgotten to make sure the mirrors were not folded in when putting up the windows, but I'd like to not have to remember this!
Anyone know of any other non-intrusive measures I can try? Is there a way to adjust it so that it does not fold in so far? Otherwise, it is going to be looked at by the Jag dealer and we know what then happens! $$$.
Old Sep 16, 2023 | 12:19 PM
Bill400's Avatar
Default Review post #7
Roll the windows down for clearance. Electrically fold mirrors. Manually pull the problem mirror out to match the correct mirror plus a few degrees.
hear a snap of engagement? If not apply WD40 liberally to the joint. Try again. Rock the mirror wing against the stop.
Let us know about your success.
Old Sep 16, 2023 | 07:07 PM
ralphwg's Avatar
From your signature it looks as if you are in the wrong forum. This is the X150 Forum (USA 2007-2015) XKs and XKRs. Your signature shows you owning an X100.l You will have much better luck addressing your issue there. Good luck.
Old Sep 17, 2023 | 03:49 AM
This is the first sage advice I've read for the power folding mirror not closing/opening to the correct position. I tried this and you definitely have to "unfold" the mirror more forward to get it to pop back into the drive as you fold it back in. Unfortunately, this did not work.......
Exactly. The X100 mirrors are SIMILAR to the X150 but not IDENTICAL.
Old Sep 17, 2023 | 05:30 PM
guy's Avatar
guy
In my case, there was significant oxidation of the mirror’s mounting assembly. We had it cleaned up, lubed, and now it operates correctly.
benzjag
Dec 13, 2017 11:12 PM
kenatofc
Aug 19, 2017 08:10 PM
Piersman
Jun 23, 2016 06:28 AM
rrosscoe
Mar 2, 2011 12:43 PM
topherscott
Jun 28, 2010 04:12 PM
