New purchase XKR vibration???
Old May 17, 2016 | 06:02 AM
scubayachts's Avatar
Default New purchase XKR vibration???
Hello everyone,
I just purchased a 2010 XKR with 29k miles on it (read to ppi or not to ppi thread) and have a question about ride quality. I know this is a GT and is supposed to be firm but something just seems a little off???
Ive never driven another xk or xkr for that matter so I have nothing to compare mine to but I feel like there is too much vibration on the highway. I have a very faint vibration in the steering wheel and the seat through the 60's and becomes noticeable right at 70 and the worst between 75-85 which really stinks since I crusie control on the highway at 80. Accelerating through 90 the car seems to really smooth out and most of the vibration goes away and I feel like that is what the car is supposed to feel like.
What do all your cars xk/XKR's feel like on the highway? Should I be feeling these vibrations? I dint think I should so what's my first step to correcting this before it drives me up a wall haha?
Old May 17, 2016 | 06:14 AM
Chaos236's Avatar
99% sure this is a tire issue. Have them rebalanced(road force),could be a broken belt in the tire.
Old May 17, 2016 | 06:57 AM
jagtoes's Avatar
Yep I agree here this is the 1st place to look. Also look at the tire tread and see where the wear is as your next step would be to get a 4 wheel alignment depending when the last one was done. Also how old are your tires , check the dates but I assume they have been replaced. I have a 2012 XKR and it rides smooth but firm and no vibration up to the speeds you are talking about.
Old May 17, 2016 | 09:05 AM
Greek175's Avatar
beyond the tires, when you spin balance, check to see if you have a bent rim and if tires and rims check out, then gravitate to checking wheel bearing and rear diff. Those are all the typical culprits that I have encountered with XK's
Old May 17, 2016 | 09:10 AM
Queen and Country's Avatar
My guess would be flat spot on tires from lack of use.
(Christie would say we have improved the roads to where people can feel small vibrations)
Old May 17, 2016 | 10:01 AM
flyc2c's Avatar
x2
Old May 17, 2016 | 10:14 AM
ferraripete's Avatar
this is a possibility. put approx. 38 psi in each of the tires and drive a bit to see if the tires become more round? if that does not work you should go have dynamic balancing done. from that you will learn a lot.
Old May 17, 2016 | 12:15 PM
CleverName's Avatar
My 2010 is experiencing the exact same issue, and new tires/balance did not fix the problem.
In my case the vibration worsened in sweeping left turns and lessened in sweeping right turns, pointing to the passenger front as the likely culprit when it loads up in stress.
I can't feel any play in the bearings, but that doesn't mean there isn't damage there showing up under heavy loads. I just ordered a new front hub and bearing assembly to cover that base next.
BOL
Vince
Old May 17, 2016 | 12:23 PM
Where did you get one from? Thx
Old May 17, 2016 | 02:05 PM
CleverName's Avatar
Rockauto
V
Old May 17, 2016 | 02:26 PM
richzak's Avatar
This becomes an interesting post, as you did not trust the dealer, Madison Jaguar and took the Jaguar to what you thought was a top notch Jaguar independent shop.
I would think the inspection by the shop you chose would have taken the Jaguar XKR out on a run or a road test at varying speeds of some kind.
It may be hard to pin-point but would have to agree that tires and an alignment might be in order to correct the problem.
The last thing you want is to start putting money into the vehicle immediately after making the purchase. What a bummer that would be and would certainly create some burnout on the vehicle and the Jaguar brand.
This is a learning experience to see and follow. No matter who inspected the car, less than one week later, you are experiencing problems.
Not fun I am sure. Go for the tire check and alignment first. If not resolved, see a brake specialist to determine problems with rotors, pads etc.
Make sure all tire pressure meets the requirement of the car.
Hope it works out for you.
Old May 17, 2016 | 06:34 PM
ralphwg's Avatar
It may be as simple as one of the tires being over/under inflated. Check all four tires to ensure that they are inflated properly before doing anything else. there is a label on the driver side door jamb that has the proper psi on it. Good luck!!
Old May 19, 2016 | 11:37 AM
Lothar52's Avatar
Originally Posted by CleverName
Rockauto
V
Can you provide a link my good man? Is this OEM?
Old May 19, 2016 | 11:50 AM
Lothar52's Avatar
nevermind I found it... was it the wheel bearing and hub assembly that you purchased for about 119?? same for all 4 tires no?
Old May 19, 2016 | 09:06 PM
CleverName's Avatar
Yes, $119
As far as I know it should be fronts only.
The part showed up today. Made by Timken (in the UK) and looks good..
A quick walk through the service manual says this should be a snap to install.
Vince
Old May 20, 2016 | 12:44 PM
agentorange's Avatar
With my used XKR the causes were:-
1) Bent rim
2) Out of balance front tyres
3) Flat-spotted OEM Dunlops that were also turning into hockey pucks, a common problem in the desert SW.
Another thing to check is the state of the hydraulic filled bushings. One of those let go on my car recently.
Old May 22, 2016 | 10:42 PM
CleverName's Avatar
Problem Solved...
Hope the OP has success as well....
Mine was indeed the bearings, and replacing the front hub assembly has returned a smile to my driving experience.
Very easy job for those mechanically inclined. Whole task was about 3 hours, including a run to the auto-parts store for a $3 tool I did not have.
Vince
Alli Quinninho
Dec 22, 2020 03:00 AM
powerhouse
Aug 1, 2016 06:39 PM
U2vertigo1
Apr 4, 2016 02:58 PM
XxSlowpokexX
Apr 1, 2016 08:47 PM
JackJohn
Mar 28, 2016 08:59 PM
