O2 Failure…with no code?
Old Feb 18, 2025 | 01:00 PM
XKDreams's Avatar
Default O2 Failure…with no code?
My ‘15 XKR is throwing a code P0101, which is the Mass Air Flow Sensor. So, I’ve ordered a new sensor.
I’m using my OBDLinkMX+ which I just started playing with, and in one of the status displays, it shows a 0.0 voltage for O2 sensor 1, and normal voltage for O2 sensor 2. Yet, there is no failure code thrown for O2 failure. As well the event log shows that Fuel Systems 1&2 are operating in closed loop mode, which needs operational O2 sensors. So, is the 0 voltage on sensor 1, an anomaly with my OBD2 tool? Whatta ya think?
Old Feb 18, 2025 | 03:45 PM
sony2000's Avatar
The MAFs are an item, that can be cleaned.
Old Feb 18, 2025 | 11:03 PM
XKDreams's Avatar
Yup..understand that. I’m asking about the 0 volts in the 02 sensor, with no code displayed.
Old Feb 19, 2025 | 02:39 AM
JagV8's Avatar
Depends. Are all the OBD monitors set (aka complete)?
Each that isn't causes many codes to be unable to flag.
Also, any flagged codes also suppress many others.
Old Feb 19, 2025 | 03:38 AM
RichardS's Avatar
The fuel trims are spot on and identical so, assuming those are being correctly displayed, the O2 sensor must be working properly and it's some kind of glitch with the OBD reader.
Richard
Old Feb 19, 2025 | 03:40 AM
b1mcp's Avatar
I'm almost certain that Bank 1 O2 sensor will be a wideband type and therefore you cannot measure voltage. They work by varying current. You may find a different PID in your OBD tool that shows Current or Lambda value to use instead.
If your STFT is OK (which it is) then your sensor is OK.
Old Feb 19, 2025 | 03:54 AM
RichardS's Avatar
I believe you are correct. All the sensors in each bank will be identical so all the OP needs to do is check the voltage for all 4 sensors. He should see the 2 upstream sensors showing 0V and the 2 downstream sensors showing a voltage.
Richard
Old Feb 19, 2025 | 03:55 AM
Pastor_x's Avatar
I have a same issue with OBDLinkMX, but car runs well and service guys says no any problem.
Old Feb 20, 2025 | 10:49 AM
XKDreams's Avatar
Good info everyone, THANK YOU!
And by the way. I cleared the codes, and the P0101 has no come back. The MAFS i ordered is to be delivered tomorrow. I’ll probably replace it for assurance.
Jimmyrn85
Dec 22, 2023 04:06 PM
Captain Bob 369
XJ40 ( XJ81 )
Oct 25, 2023 07:40 PM
EsRay
May 18, 2021 02:36 AM
Bigvettefreak
Oct 24, 2015 08:47 PM
zibby_uk
Nov 1, 2012 09:41 AM
