oil leak
Old Dec 14, 2011 | 08:12 PM
Dan's Avatar
Dan
Default oil leak
I had an oil change a few weeks ago and then started seeing oil drips on the ga. I took the car in this morning and it turned out to be the rear main seal. Does this seem odd for an 08 with 27000 miles?
On a side note the dealer provides loaners and I am now driving a shiny new......Toyota corolla
Old Sep 18, 2012 | 04:03 PM
ejjbee's Avatar
Hi Dan, where exactly was the oil leak? Was the seal replacement a sunstantial effort?
Old Sep 18, 2012 | 04:09 PM
rscultho's Avatar
Shouldn't be happening...that's a defect in build most likely. Car is to young to have that problem from normal wear...
Old Sep 18, 2012 | 05:13 PM
amcdonal86's Avatar
Yikes. How much did this cost to fix? How long have you had the car?
Old Sep 19, 2012 | 06:27 AM
mosesbotbol's Avatar
I'd be all over Jag to pay for this. Shouldn't happen and not normal for Jaguar.
Old Sep 19, 2012 | 06:55 AM
dutch07xk's Avatar
Maybe they overfilled?
Old Sep 20, 2012 | 10:11 AM
Dan's Avatar
Dan
It was covered under warranty and they had my car for two days.
Oddly enough I was rear ended in the Corolla about 3 miles from the dearlership too. Glad I wasn't in my jag or in an expensive loaner!
No more oil leaks either. It does seem odd that it happened to a 4 yr old car and they didn't say one way or the other as to the frequency of this problem.
Old Sep 20, 2012 | 10:23 AM
ejjbee's Avatar
Glad you're fixed now Dan. I should be going in with mine in a couple of weeks for further checks, but it quite likely it's a rear main seal. Will take up with Jag as it's quite embarassing for a 25k mile car to leak. Even though mine's just 4 years old!
Will post progress ...
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
