P0106 MAP Sensor rich LTFT advise please
Old Dec 20, 2019 | 04:13 PM
trkyam's Avatar
Default P0106 MAP Sensor rich LTFT advise please
2010 XK 5.0 53k miles very well maintained.
X-pipe, rear muffler delete.
Getting P0106 DTC code, I've inspected for air intake leaks
and cannot find any, I also have installed new air filters.
The MAP sensor has been tested and is functioning properly,
I've changed the PCV valves as well, no known vacuum leaks.
When I look at my fuel trim (LTFT) in SDD I appear to be running rich.
any suggestions on how to correct this?
Old Dec 21, 2019 | 04:10 PM
Mufc's Avatar
Clean the throttle body. It is probably covered in carbon deposits and make sure you air filters are the same brand.
Old Dec 21, 2019 | 04:37 PM
Sean W's Avatar
Here are some ideas
https://www.jaguarforums.com/forum/x...07-xkr-119489/
Old Dec 25, 2019 | 09:18 PM
trkyam's Avatar
Thanks for your reply, I have already changed the plastic T tubing that goes into my throttle body,
so that is not the issue. I have not however cleaned my throttle body yet,
does this involve removing the throttle body or just spraying from the front?
Old Dec 25, 2019 | 11:23 PM
Cee Jay's Avatar
You COULD use that CRC GDI Intake Valve and Turbo Cleaner, spraying it into the air intake prior to the Throttle Body. There is a thread in here about it. It's mostly for cleaning carbon off intake valves, but I'm sure it'd do SOMETHING to the TB.
Old Dec 26, 2019 | 06:05 AM
trkyam's Avatar
I'm considering removing my MAP sensor (directly mounted into throttle body) and spraying GDI cleaner into the hole,
as this gets me closest to the valves, good idea?
Old Jul 7, 2020 | 01:43 AM
trkyam's Avatar
Just an update, SDD takes FOREVER to update LTFT values, as in multiple drive cycles and or miles.
I used a ELM device to get live data, this was way more effective.
The reason my LTFT was so far off was because I had disconnected my intake ducts in order to
clean the intake valves with CRC intake valve cleaner and SDD did not have enough time to
readjust and take new averages of the LTFT after running the engine with the intake open.
will upload my current values.
Old Jul 7, 2020 | 01:48 AM
trkyam's Avatar
Old Jul 7, 2020 | 07:11 AM
Stuart S's Avatar
You installed new air filters. If they weren't a matched pair, that could be the cause of your problem.
See this old thread from 2013:
https://www.jaguarforums.com/forum/w...ad.php?t=92749
Old Oct 4, 2023 | 01:55 PM
trkyam's Avatar
https://www.jaguarforums.com/forum/x...-242561/page2/
close out
vincent661983
Nov 2, 2018 04:46 PM
frcraig
Oct 21, 2018 05:56 PM
injuhneer
XJ40 ( XJ81 )
May 30, 2014 08:47 PM
Spurlee
Feb 10, 2011 10:15 AM
Elrod the Albino
Jan 13, 2011 01:57 PM
