Possible to use a 2012 shifter in a 2008?
Old Aug 13, 2017 | 10:37 PM
nasomi's Avatar
Default Possible to use a 2012 shifter in a 2008?
The assembly was upgraded, any idea if it's backwards compatible?
Old Aug 14, 2017 | 01:33 AM
Cambo's Avatar
No there is totally different transmission software between the 4.2 and 5.0 cars
Old Aug 14, 2017 | 07:20 AM
nasomi's Avatar
I figured as much, shame. My chrome has chips and there's a bit of wear on the knob, but a new one is $400. I figured if I was going to be spending that much, maybe look for a nicer one.
Old Aug 14, 2017 | 08:34 AM
michaelodonnell123's Avatar
This. British Autowood > Gearknobs
Attached Thumbnails Possible to use a 2012 shifter in a 2008?-136893d1475769182-interior-praise-xk-126018d1456436508-burl-walnut-shift-knob-beautiful-workmans.jpg
Old Aug 14, 2017 | 10:50 AM
8bit's Avatar
Is it purely a software issue? I understand that early 5.0 X150s still had the 6HP26 box as fitted to the 4.2s, I did find myself wondering what the stumbling block would be...
Old Aug 16, 2017 | 11:42 AM
davchr's Avatar
I don't see why it would be a software issue. The shifter, whether a rotary knob or linear rod, operates switches that tell the software what is selected. I have never had either one apart, but if you can get at the switch contacts you should be able to wire them to the software/hardware interface to accept the input from either shifter. Both shifters have five positions and switches - P, R, N,D, and S. The software does not care how or what actuated the switches.
Someone that has them apart can comment if the switch contacts are accessible or burried in a CANBUS controller.
It might take a little work to make the rotary knob retract when shutting the car off.
Old Aug 16, 2017 | 11:50 AM
110reef's Avatar
It seems to me that during my search for a 2007-ish XK I ran across someone who had bought but not installed the knob type shifter to replace his stick-style shifter, and he was including it in the sale. That doesn't necessarily mean that the switch could be accomplished, but I guess he thought so.
Old Aug 16, 2017 | 02:26 PM
Cee Jay's Avatar
It'd be easier and cheaper to sell the 2008 and buy a 2012 (or any 2010+). Plus, you'd get all the added goodies to go with it.
Old Aug 17, 2017 | 12:21 AM
ralphwg's Avatar
