Power Supply recommendations for 07 XK when using SDD
Wondering if any particular power supply recommendations for when using SDD to flash modules? It’s for on a 2007 XK. Thanks in advance
And if you serch SDD power supply you find others.
It's important the power's clean and filtered, low ripple, etc. Noisy cheap power supplies can affect module flashing integrity. Jaguar recommend 50 amps but for the 2007, even 25-30 amps would be sufficient.
While flashing modules and such, my pre-battery required was at maximum 35 amps. A person could probably run SDD with a 30 amp for a couple hours before it became an issue.
Also, going through a battery, the battery IS the filter. It takes out all the buzz and fluctuations out of even a cheap charger. Of course the battery has to be in decent condition regardless.
freeb1703
Jul 20, 2024 02:15 PM
