preventative maintenance convertible top
Old Feb 17, 2019 | 05:20 PM
2004vdp's Avatar
Default preventative maintenance convertible top
Hello, i was wondering if anyone has changed the hydraulic fluid or done anything else just as these cars reach 10 years of age. This is for a 2008 convertible with 50,000 miles. i have already done brake fluid, thermostat housing, water pump, battery, fuel filter. The convertible top is still working fine.
Old Feb 17, 2019 | 08:00 PM
kj07xk's Avatar
This is probably a case of “if it ain’t broke, don’t fix it “.
Only heard of one or two cases of work to that hydrolic system on this forum.
Old Feb 17, 2019 | 09:47 PM
Stuart S's Avatar
I agree. The next fluid on your list should be the transmission fluid. Didn't you replace the coolant when you did the Tstat and water pump? Why did you replace the water pump? They usually don't go bad on the 4.2L models.
Old Feb 18, 2019 | 03:41 AM
2004vdp's Avatar
hi, yes i did coolant with tstat and water pump. there was a bit of plastic stuck in the water pump fins, so when opening to check the water pump, i just replaced it.
Old Feb 18, 2019 | 03:42 AM
2004vdp's Avatar
also transmission fluid and pan were changed, as well as diff fluid.
jaguarcraver
Nov 15, 2013 05:30 AM
RudeboYRockstaR
Jan 27, 2013 08:25 PM
mjlaris
Sep 28, 2011 06:35 AM
Mayor111
Oct 28, 2010 01:32 PM
Revopop
Apr 1, 2010 09:52 AM
