PSA: Replace your 2 piece lug nuts
Old Jul 8, 2019 | 01:33 PM
shemp's Avatar
Originally Posted by Sean W
I'm more a fan of this one. I prefer to bar to be 90 degrees to the wheel. Regarding the sockets Q&C mentions, I believe they help preserve the wheel paint but don't think they protect the lug nut?
https://www.amazon.com/dp/B00JFH6D1E...v_ov_lig_dp_it
ooh I like that one.
Old Jul 8, 2019 | 01:51 PM
Queen and Country's Avatar
I was just considering this one till Sean posted a tempting option.
Amazon Amazon
Old Jul 8, 2019 | 01:59 PM
shemp's Avatar
Whoa!. I'd probably dent my door in the process of removing the lug
Amazon Amazon
Old Jul 8, 2019 | 02:02 PM
Sean W's Avatar
https://www.amazon.com/Neiko-03970A-...e%2C158&sr=1-3
Yep, I like that one too. 24" of leverage should definitely break any nut loose. Another advantage of that one is that you can use your jack under it if needed, to gain advantage of the weight of the car to loosen a frozen lug nut. Right now I just have a 1/2" breaker and socket.
Old Jul 8, 2019 | 03:16 PM
Many Thanks. I did not know that trick, could have saved me much agony in the past.
Old Jul 9, 2019 | 05:59 AM
Stuart S's Avatar
... Also buy one of these and keep the 19mm socket in your glovebox. For one it will prevent wheel from being scratched up, but its a polite way of making sure the pimple faced dummy at the tire shop knows what socket size to use.
https://www.ebay.com/itm/3Pc-Thin-Wa...cAAOSwa1ZcUL-1
I agree; you definitely should keep a 19mm socket in your car. But why pay $13.99 for a 3-piece set with 2 sockets that you'll never use when you can buy this and save $10 (or more with a store coupon)? I'm fortunate to have a Harbor Freight store close by. Otherwise, buy it online.
Old Jul 9, 2019 | 08:28 AM
3 big reasons. The socket I posted is a thin wall socket and fits where regular impact ones dont. I do have a problem with this on my truck that has aftermarket wheels. I have to carry a regular non-impact 3/8 drive deep socket in my glovebox just to take the wheels off. Its got a nylon lining to prevent eating into the wheel. Its $14 for 3 sockets or $10 for one. Keep the 19mm and sell the other 2 and make money!!
Old Jul 9, 2019 | 10:00 AM
  #28
Cee Jay's Avatar
...............why pay $13.99 for a 3-piece set with 2 sockets that you'll never use when you can buy this and save $10 (or more with a store coupon)? I'm fortunate to have a Harbor Freight store close by. Otherwise, buy it online.
That's the socket I have! I also have a torque wrench in a case right next to the spare.
Old Jul 9, 2019 | 05:54 PM
Stuart S's Avatar
See my Post #10 in this 2014 thread: https://www.jaguarforums.com/forum/x...e-nuts-132368/
It's still the same price.
Old Nov 1, 2021 | 09:09 PM
  #30
chemosabe's Avatar
I too have been surprised at how flimsy the original lug wrench is… and how tightly the lug nuts were torqued. Good solution.
Old Nov 2, 2021 | 05:32 AM
  #31
guy's Avatar
guy
it seems some having issues with the engineered solution, didn’t follow the rules;
1. do not use an impact gun
2. use the appropriate metric socket
3. torque appropriately.
I always “break” the initial hold by using my 1m breaker bar. No issues whatsoever.
incidentally, the wrench in the boot is for emergency use, not continual maintenance use. I wouldn’t expect the hollow handle to take the abuse of continual usage.
Old Nov 2, 2021 | 08:58 AM
  #32
J5hort's Avatar
Maybe a little anti-seize on the threads as well. I tend to rotate tires every oil change for my vehicles. It is not bad practice to remove wheels and inspect brakes, etc every 3K-5K miles. This way you are less likley to be in a situation where the lug nuts are completle frozen from not being removed in decades. I still stand by the one piece solid lug nuts as the 2 piece tend to deform. I have experienced this on other vehicles, but due to the wheel style was able to easily remove. The Jag and Senta wheels and deep cavity of lug hole area seemed to introduce more difgficulty in trying to remove the cap portion of the lug nut to get to the actual threaded part.
Old Nov 2, 2021 | 01:30 PM
  #33
xalty's Avatar
1. always use an impact gun
fixed that for you
Old Nov 2, 2021 | 02:34 PM
  #34
kj07xk's Avatar
Don’t think I’d put anti-seize on the threads. On the mating surfaces, yes (flat part of nut & back of wheel).
Old Nov 11, 2021 | 05:37 PM
  #35
chemosabe's Avatar
Based on this thread and others, I became fearful of being stuck on side of road- unable to change a flat. So I did an inspection- each lug nut, one by one- removed, inspected, and a touch of anti-seize on each one before installing to spec. Here is what I found. They were all perfect, I great shape, and looked very well-built and sturdy. In other words the PO’s of my ‘09 Portfolio always did the work right (or had the tire work done by pros). Also, I have placed a 19 deep with beekeeper bar in my trunk so I don’t get caught. Thanks to all for the heads up.
Old Nov 12, 2021 | 08:25 AM
  #36
jons's Avatar
when i lived in MA i used a thin coat of molykote on the face of the brake disc where it contacts the wheel, and on wheel bolt threads. never failed me.
Amazon Amazon
that was over ten years ago, and i still have this one tube of it, more than half full probably. pretty sure it affects torque reading but just go 3-5 pounds over spec and you're good.
staggerwing17
31
Nov 8, 2021 08:06 AM
MWave
16
May 18, 2019 05:37 PM
giandanielxk8
Apr 3, 2018 10:27 AM
Jon89
Jun 29, 2013 02:16 PM
Noxparadise
Dec 1, 2012 10:16 PM
