Putting the Parking Brake in Service Mode for Brake Replacement
Old May 4, 2020 | 08:16 PM
silvertonesx24's Avatar
Default Putting the Parking Brake in Service Mode for Brake Replacement
I am preparing to replace rear brakes and rotors on my XKR. I read it is best to disconnect the negative terminal so the parking brake properly resets. Can I do this with a diag tool? I have a Ht200 which has a ton of editable true/false statements in the PBM control, but see nothing on service mode. I have a SDD on the way as well.
I'd prefer to avoid having to reset all my settings that would come with a battery disconnect.
Old May 4, 2020 | 10:25 PM
scottjh9's Avatar
try this....with battery connected, turn ignition switch to position 2. then hold the park brake in the release position and while holding it, turn ignition off and remove key...if no park brake light comes on, then success
Old May 4, 2020 | 10:30 PM
Cee Jay's Avatar
That's what I do. Basically just Not Engage Parking Brake when I shut it down.
Old May 5, 2020 | 01:01 AM
peterv8's Avatar
I didn't think the parking brake engaged automatically when shutting off the engine, mine doesn't!? Is it different on the 5 litre?
Old May 5, 2020 | 01:58 AM
Sovejag13190's Avatar
Sorry but i don't understand your response. It's not possible turn off and remove key ont XKR.
Old May 5, 2020 | 04:27 AM
JagV8's Avatar
What? Of course it is.
Isn't it?
You turn the engine off and remove the key after driving, every time... Do the same except the paddle bit first.
Old May 5, 2020 | 05:02 AM
tommytess's Avatar
Default Mine
When I did mine I released the handbrake,and then disconnected the battery and had no problems.
Tommy
Old May 5, 2020 | 06:22 AM
trkyam's Avatar
Leave the parking brake off, unhook your battery, remove the parking brake cable from the caliper (easily done)
change pads, re-attach cable to caliper, reconnect battery.
Old May 6, 2020 | 03:11 AM
8bit's Avatar
I've done rear discs and pads a few times on both my XKRs (X150s). I never disconnected the battery and there's no need to disconnect the parking brake cable or put the rear brakes in service mode. Just ensure the park brake is not engaged before you lift the car, when you take the caliper off the mounting bracket use a cable tie round it and the spring so the caliper is not dangling by the hose or the park brake cable. Done it that way a good few times, never had any issues.
If you do want to reset the park brake then yes, disconnect the -ve battery terminal for a few seconds or so and reconnect. When you get in the car and start it it will tell you to press the brake pedal and apply the parking brake, that will reset it. You will also have to reset the one-touch windows, search here for that procedure, it takes a few seconds only. You won't lose any seat/mirror position memories or anything like that, these are all stored on non-volatile memory.
Steven Cooper
Jun 12, 2020 01:48 PM
David Meier
Oct 3, 2019 08:37 PM
‘Oleguy
Jan 18, 2019 08:00 AM
MikeofBonsall
Dec 2, 2018 03:56 AM
millenia man
Jan 29, 2011 05:06 PM
