Rear diff oil for 4.2L XKR
Old Apr 14, 2021 | 07:28 PM
JaguarXKR's Avatar
Default Rear diff oil for 4.2L XKR
Hi All,
Can someone direct me to the correct rear end final drive oil to use in my differential? JLM21847 (75W-140) or C2D3650(BOT 720)?
Thanks!
Old Apr 14, 2021 | 08:01 PM
Sean W's Avatar
Service manual calls for M2C 192A Synthetic which is a 75W140 synthetic gear oil but I don't know if it has friction modifiers
Old Apr 14, 2021 | 08:10 PM
Stuart S's Avatar
Old Apr 14, 2021 | 09:11 PM
XKRAU's Avatar
75w-140 GL5 gear oil - I use Amsoil 75w-140 severe gear oil. There is no drainplug, so you need to either split the diff cover open or vacuum / suck out the old diff oil which is what I did.
Old Apr 15, 2021 | 05:30 AM
guy's Avatar
guy
no. friction modifiers are not required in that diff.
Old Apr 15, 2021 | 08:49 AM
V7Sport's Avatar
A few photos and description of my differential oil change experience are in the attached link.
https://www.jaguarforums.com/forum/x...4/#post2251156
Old Apr 15, 2021 | 08:51 AM
V7Sport's Avatar
Thank you Stuart for posting the summary of 4.2l fluids and routine maintenance parts. Very handy!
Old Apr 15, 2021 | 09:26 AM
80sRule's Avatar
I went with two o these:
https://www.fcpeuro.com/products/bmw...z4-83222282583
There's tons of options out there, Liqui Moly is acceptable, among many others. I've used the DSG fluid, diesel purge and several others products from them in VW/Audi cars, and bought from FCPEuro many times; so I went with them and it's been uneventful since the change 10k ago in my 07 XKR.
Old Apr 15, 2021 | 10:01 AM
panthera999's Avatar
Just a note that the first 2014 url (https://www.jaguarforums.com/forum/x...s-list-122939/) in post 1 says that the ATF in the ZFhp26 uses Shell 1374.5 (true) and Dexron III (not true). Most folks know this by now, but don't want newbies to be led astray. There are Shell 1374.5's out there, including ZF's LG6, and a Ford variant, but Dexron III isn't one of them. If someone has a spec sheet from ZF that says Dexron is acceptable, please post it.
Panthera
Old Apr 15, 2021 | 12:19 PM
Sean W's Avatar
Panthera
Yep agreed. The guy hasn't been around since 2015 and although he said it wasn't a typo and even though this thread is about Differential oil, I'm going to add a comment to start the ATF wars, but really as Panthera said, correct some ATF info stated in the 2014 thread linked above:
Shell Spirax S4 is compliant with M-1375.4. Shell makes M-1375.4. We all know that.
Shell Spirax S4 also meets requirements for Fords requiring Mercon SP type aka, Ford Type D fluid.
Dexron III was compliant with Ford built between 1983 - 1996 where Mercon Performance was called for and specifically should not be used where Dexron® VI, Mercon® V or Mercon® SP are required. Not that hard to google this stuff but maybe there was less info on the inter web back then:-). That info is from Castrol.
Old Apr 15, 2021 | 02:52 PM
JaguarXKR's Avatar
Thanks! I see the note..
Differential, Rear......GL-5
All TEMPS......75W-140
80W-140 Synthetic Long Life Gear Lube
Does Jaguar have a released part number for the 75W-140? I have had two different places recommend either JLM21847 (which looks to be a 75w-140) or C2D3650which is "BOT 720" and is released for almost all older style cars (X100's X300's, 308's, including the F-type.. ) kinda scratching my head what this fluid is.
Old Apr 15, 2021 | 03:54 PM
snip.
Certainly no interest in that discussion anymore, I hope. We beat it to bloody death on the BMW forums, certainly, as I assume was done here as well.
Kind of like starting an oil thread.....
Cheers---
Old Apr 16, 2021 | 07:08 AM
Stuart S's Avatar
andyxkrbroke
Jul 27, 2017 02:58 AM
gabrielbecheanu
Apr 23, 2016 12:45 AM
p-Rock
Mar 7, 2013 06:01 PM
pan84
Sep 10, 2011 07:14 AM
chalkie28
Nov 27, 2010 01:03 AM
