Rear fog bulb, replace?
Old Dec 23, 2017 | 11:12 AM
prodigy215's Avatar
Default Rear fog bulb, replace?
Am i able to replace my rear fog bulb or is it led?
-2008 Jaguar XKR
Old Dec 23, 2017 | 12:29 PM
pk4144's Avatar
I have a 2010 and I think it's different for '10 and newer, but with ours it's built into the lens assembly, so you have to get the whole round light (including the reverse light). Also, ours are LED's. But I don't know about 08.
Having said all that... there is also a small chip in the lamp/lens unit that can go bad. That may be it. But, again, you're replacing the whole thing, I think.
Old Dec 23, 2017 | 02:31 PM
sov211's Avatar
The rear fog is an LED unit in all the X150 cars - and it should not need replacement. You do know that there is only one reverse lamp and one fog lamp on the 2007 and 2008 cars?
Old Dec 23, 2017 | 09:45 PM
CleverName's Avatar
I actually bought a European Fog for my '07 to make both sides symmetrical. Always hated that one side was backup and the other fog... Figured two fogs would be bright enough to use as back-up lights anyhow...
Never did install it before I got my used 2010, so essentially I fixed the problem for about $40,000... Sorta.... First thing pointed out to me is that the right fog on the 2010s commonly fail, and sure enough it was the first part I ordered...
Old Dec 23, 2017 | 11:26 PM
Cee Jay's Avatar
Yeah, I just found out that half the LEDs on my Right Fog are inop. Doesn't really affect me as I never run 'em anyway.
Old Dec 25, 2017 | 12:36 PM
RedRider48's Avatar
No one drives backwards in the fog? Ho, Ho, Ho!
Old Dec 26, 2017 | 07:39 AM
prodigy215's Avatar
Thanks for the reply guys. I was asking because i would replace the bulb with a yellow one if it was possible lol. It sucks to only have one reverse light. So the only way to do it is to buy a European XK fog from what i see
Old Dec 26, 2017 | 09:32 PM
ralphwg's Avatar
I think there is an older thread on the subject of changing from a one side backup light to a two side backup light. If so, you can find it by entering change from one side backup light to two sided backup lights, or something similar.
Old Dec 27, 2017 | 01:03 AM
CleverName's Avatar
If you're looking for both sides to be alike, you'll have to choose between two backup lights, or two fog lights.
As I said, I was going for two fog lights, and figured to wire in a couple diodes so the fogs worked in both modes.
I still have the UK fog light, as I never installed it before getting my XKR. Sad part is it is now somewhere in storage (I know not where), or I would offer it up. Not even sure I can recall what I paid for it, but I think about $150. I just watched FleaBay.UK for a few months for one to show up.
If interested, PM me, and I can make an effort to dig through some boxes to see if I can get lucky....
Old Dec 27, 2017 | 09:29 AM
Sean W's Avatar
OK maybe dumb question but I haven't pulled the unit to check. Question is for PRE - LED units 07-09. Is there a difference in the Lens/reflector for the rear fog light or is it merely a "red bulb"?
It can't be that simple because if it were I would wire my rear fog to the back up terminal and change the bulb.
What makes the left side unique compared to the right sans wiring?
Old Dec 27, 2017 | 09:56 AM
britannia's Avatar
I bought a used UK LH unit for $50; fitted right in, identical except for 'bulb' colour (white).
Easy to wire................don't drive the XK ('07 coupe) at night ; so just did it for fun!!
and stop the questions at the cafe!
Cheers, Adrian
Old Dec 27, 2017 | 11:56 AM
CleverName's Avatar
Both left and right are LEDs with circuit boards attached. Not something I felt was easily modified. I don't recall the number in each but I think 3 LEDs per unit.
Old Dec 27, 2017 | 03:35 PM
Sean W's Avatar
for 07-09? No LED that I'm aware of.
Old Dec 27, 2017 | 04:00 PM
u102768's Avatar
They are LED's even on the 4.2 litres.
Old Dec 27, 2017 | 04:23 PM
Sean W's Avatar
I'll be dipped. I thought there were a few internal LED bulbs but duh. It's staring right at me in the wiring diagram. When in doubt, read the manual I guess. Think before you type Sean. Geez. Thanks guys.
Old Oct 27, 2025 | 08:20 PM
Steve in Denver's Avatar
Default 2007-2009 XK FOG Lamp
The rear lamp on the left side is definitely a FOG Lamp and there are no Bulbs to be replaced.
Push the lower button on the dash and the FOG lamp should come on.
Now that I look at a picture I took of the lamp when I had it out, it even says FOG on itl.
Old Oct 27, 2025 | 09:33 PM
Stuart S's Avatar
All 4.2L models, including 2009, have a single backup light and a single rear fog light. That fog light is always on the driver's side, because that's closest to the center line of the road. Don't forget that the UK has a lot of rain and fog, so that fog light marks the center of the road for the drivers behind you.
The 5.0L models have two backup lights, one on each side.
It is not uncommon for a 4.2L owner to be told by a driver behind you at a gas station that one of your backup lights is out. I've been told that many times. American drivers expect to see two backup lights. The single backup light is just one of the British quirks that add to the charm and character of our beloved 4.2L models.
hisport
May 25, 2022 07:04 AM
RWS1965
May 23, 2021 09:17 PM
keithavfc
Jul 11, 2016 07:10 AM
Rey
Feb 1, 2013 07:02 PM
tvn300
Feb 8, 2010 01:58 PM
