Red Part of Right Rear Outer Tail Light Missing
Old Apr 22, 2024 | 05:20 PM
Originally Posted by trkyam
I've actually removed the red cover, it can be pried off with a flat head after heating with a hair dryer ......
Did you pry it off a 2010 Coupe in Birmingham, Alabama?
Old Apr 22, 2024 | 07:05 PM
trkyam's Avatar
Old Apr 28, 2024 | 04:12 PM
billqs's Avatar
While I was unable to locate the coolant leak, I had success prying off the red tail light!
what is a good adhesive to apply this to the clear tail light on my XK?
Old Apr 28, 2024 | 04:37 PM
Cee Jay's Avatar
Plastic modeler's cement?
Old Apr 28, 2024 | 09:42 PM
CurtJ's Avatar
Before using the plastic modeler's cement, I'd experiment with it using the remainder of the lenses on your donor lamp. Modeler's cement works by chemically melting the model plastic temporarily so that the plastic parts fuse together. The reaction only works on specific types of plastic. If the lens is styrene then all is good, but if it isn't styrene then at best it won't bond and at worst it the melting will be permanent.
I would use CA super glue -- Loctite makes a gel version that is much easier to control and won't run all over the lens.
Old Apr 29, 2024 | 06:07 AM
SeanU's Avatar
I would consider a 2 part epoxy
JB Weld Clear Epoxy JB Weld Clear Epoxy
... the tail lamp is exposed and subject to harsher conditions... CA glue can be brittle and does not always work well on every type of plastic. As others mentioned, experiment with a few types of glue before doing the permanent fix.
Old May 6, 2024 | 08:10 AM
fritzthecat's Avatar
Clear silicone…
https://www.homedepot.com/p/Loctite-...8570/303769575
or E6000…
Amazon Amazon
Old May 6, 2024 | 11:27 AM
  #28
billqs's Avatar
I used Gorilla Glue which is a Polyurethane Glue. So far it has adhered well. I let it adhere for 24 hours before I drove it. So far it has held well. I looked up the type of plastic for tail lights and it is supposed to be PMMA. I checked and Polyurethane glue is safe for PMMA. Should thaf fail, I have some JB Weld epoxy I will use as a back up.
Thanks to everyone, especially SeanU for help in this task.
Old May 6, 2024 | 01:13 PM
SeanU's Avatar
Good work Bill... happy the part worked out!
Old Aug 18, 2024 | 06:04 PM
  #30
nacdah1's Avatar
Hello Sean,
I am missing the same on my car 2010 XK convertible If the gentleman on this post doesn't want it I'm willing to buy it from you.
Please let me know.
Or if anyone has a part like this and wants to sell it I like to buy it.
Thank you very much
Nick
Old Aug 19, 2024 | 06:15 AM
  #31
SeanU's Avatar
Hey Nick... Bill took the part and successfully used it. I suggest trying https://www.car-part.com/ to get one from a wrecker.
Old Aug 19, 2024 | 11:17 AM
  #32
kenbowen's Avatar
These tail lights from the 2010 and up LED models are very fragile and are prone to becoming unbonded with time, much more so that the 07-09 incandescent versions. I sold a perfect condition working version(very solid when shipped) of one from a 2010 XKR and shipped it in a properly padded box to a customer. When it arrived it had already delaminated on its own just from transport. Otherwise in great shape. The customer decided to just epoxy it back on and all was well. My XKR is the older version but I think if I owned a later model I would consider installing a few spot glue reinforcements before it comes off on its own.
miamijohn
Jan 28, 2024 07:57 PM
john501
Jun 2, 2015 10:38 AM
smith356
Feb 4, 2015 03:02 PM
lanetrainman
Oct 8, 2013 11:54 PM
jagrole
May 6, 2012 06:36 PM
