Replacing CATS shocks with normal ones
Old Apr 8, 2020 | 04:19 PM
Jomiltom's Avatar
What brand and model of shock absorbers do you recommend.
My driving is not aggressive at all and I don't want to turn it into a board, but I also don't want it to turn into a boat.
Old Apr 8, 2020 | 04:21 PM
Jomiltom's Avatar
Originally Posted by jahummer
correct and not failure or errors. It works perfectly. And yes I would highly recommend considering BC Racing coilovers.
I'll look for them
Old Apr 8, 2020 | 06:47 PM
jahummer's Avatar
Originally Posted by Jomiltom
I'll look for them
https://www.bcracing-na.com
Mine were bespoke even if they are not on their website they will make them for you any way you want, spring rates and even Swift springs.
Old Sep 24, 2020 | 07:18 AM
pauledddy's Avatar
Pull the fuse to the CATS module. It is located in the left footwell.
If only it were this easy on the 5.0
Old Sep 24, 2020 | 07:55 AM
jons's Avatar
i rather like the stiff mode! i drive as fully spirited as circumstances permit (i don't see any cops. you see any cops? i don't see any cops.)
since the topic was raised, would you kindly elaborate? i've considered aftermarket suspension parts but i definitely don't want dash warnings at all times.
Old Sep 24, 2020 | 08:34 AM
thierry_1500's Avatar
Another option is to have your old cats shocks refurbished by a specialized shop.
it was possible for the X100 which had Bilstein shocks and it cost a third of the new price.
Worth checking for the X150 IMHO.
Old Sep 24, 2020 | 10:55 AM
pauledddy's Avatar
As the 5.0 has an E-Diff that talks to the suspension module, pulling the fuse on the 5.0L XK's and XKR's will cause and E-Diff Fault and Adaptive Suspension Fault. the 4.2's though are unaffected by this
Old Mar 2, 2021 | 01:37 PM
  #28
dan314's Avatar
Hey jahumner,
Thought u might be able to help. Got a “suspension fault” on ‘05 XKR and R front is abt 1/2” lower than L front. Is there a quick fix or diagnostic or is my whole CATS busted?
Thanks,
dan314
Old Mar 3, 2021 | 10:35 PM
ralphwg's Avatar
Dan - you are in the wrong Forum. This is for X150s built between 2006 and 2014. YOu belong in the X100 Forum They were built from the late 90s through 2005. Perhaps a moderator will move your post there for better answers.
autocad23
Dec 31, 2016 12:06 AM
OnebadassXJR
Jun 28, 2016 06:55 AM
pjdarcy
May 3, 2016 12:05 PM
hypoluxo
Apr 2, 2014 11:57 PM
nodisclaimer
May 23, 2013 07:45 PM
