Reset Service warning
Old Sep 7, 2017 | 03:43 PM
malx's Avatar
Default Reset Service warning
Just did an oil change on my car. Does anyone know how to reset the service required warning? I have an 2010 Jaguar XK.
Thanks!
Old Sep 7, 2017 | 03:50 PM
Cee Jay's Avatar
'Service Required' Message appears on dashboard (2009+ models in the UK, 2010+ models elsewhere)
-This service reminder message sometimes appears as a result of the battery disconnect. Reset
it as follows:
1. Press and hold the rear fog lamp switch (before the ignition is on).
2. Press the start button without applying the foot brake (do not start the engine)
3. Release the rear fog lamp switch (1sec)
4. Press and hold the trip computer cycle switch (within 1sec).
5. Press and hold the rear fog lamp switch. (within 1sec)
6. Continue to hold the trip computer and rear fog lamp switches.
7. The message center should display "resetting service mode" and then "service mode reset"
8. Release the trip computer and the fog lamp switches and turn the ignition off.
Now the caveat.... you MUST get a good rhythm going for this to work. I practice doing it several times before I actually attempt it, on a good, solid one-second tempo. One push or release per second.
Old Sep 7, 2017 | 03:52 PM
malx's Avatar
I'll give that a shot!
Old Sep 7, 2017 | 06:42 PM
bocatrip's Avatar
Funny.... I get one Oil Change every year regardless of miles. The service required message always comes on within a year. With my discounted oil change at Jaguar the message is cleared. My last oil change cost me $105 with a great coupon. I guess if you pay the $100+ for the oil change it will be cleared and you get fresh oil! I'm a cheap guy but always want things to be easy.
Old Sep 7, 2017 | 07:11 PM
ralphwg's Avatar
I just used the above method. Took about 5 or six tries to make it work. Suggestion use both hands. Be patient and persistent and you will get it. Don't give up.
Old Oct 11, 2017 | 04:14 PM
malx's Avatar
I got it done! Took a few tries but worked like a charm. Can I do the same for the Check Engine light? I fixed the issue that forced it on but I can't get it off? Or will it come off from driving?
Old Oct 11, 2017 | 04:59 PM
WhiteXKR's Avatar
In most cases it will go off after a few drive cycles if the issue is truly resolved. If not, get a $10 'ELM327' code scanner from eBay.
Old Oct 12, 2017 | 06:23 AM
JagV8's Avatar
Typical P code once fixed needs 3 warm ups before MIL goes off.
Old Oct 12, 2017 | 11:12 AM
malx's Avatar
You mean something like this? Does this work in all cars? It pushes engine codes to my phone?
https://www.ebay.com/i/221821719820?chn=ps&dispItem=1
Let me know,
Joey
Old Oct 12, 2017 | 11:45 AM
Cee Jay's Avatar
I got one like that for about $6 shipped free, but it also came with Full versions of Torque and Dash Commander, also free. Works flawlessly.
Old Oct 12, 2017 | 11:49 AM
Queen and Country's Avatar
I am waiting till they come down to $4.50
Old Oct 12, 2017 | 02:09 PM
malx's Avatar
Do you have an iPhone?
malx's Avatar
LOL. I'll PayPal you the 1.50.
Old Oct 12, 2017 | 04:36 PM
Cee Jay's Avatar
Oh, GADS no! And I don't appreciate the insinuation!
iphone
Old Oct 12, 2017 | 05:12 PM
^He spent more on the adapter than the phone.
The older iphones dont allow connection with cheap bluetooth devices. They require a wifi connection. So you can buy the wifi adapter from Amazon.
I dont believe any one of them can do more than the other. I have a bag full of the cheap adapters (android) that quit working or never worked.
Old Oct 12, 2017 | 05:52 PM
malx's Avatar
Ok thanks for the tip. I'm going to try to find a good one that works with the iPhone and that also works with my other two cars. I'll keep everyone posted!
Old Oct 12, 2017 | 05:54 PM
Cee Jay's Avatar
^He spent more on the adapter than the phone..
HAHAHAHAHAHAHA........... you clearly have no idea about anything. Ever. Since the beginning of time. And no doubt until the END of time.
Since icraps are INCAPABLE of connecting, evidently you think them superior. That's ludicrous.
ooooohhhhh, I want to SO much say a WHOLE bunch of stuff, but due to the Public Forum, I will refrain.
Old Oct 12, 2017 | 06:08 PM
I have never owned an iphone.
Only android, they are better for me.
Cant really comment if iphones are good or bad, never even used one.
Old Oct 12, 2017 | 06:19 PM
kj07xk's Avatar
Yes, Cee Jay hates anything crapple, but for those if us that are stuck with one for one reason or another, there are OBD-II readers that use wifi instead of bluetooth, and work just fine with icrap. I’ve got one, and have used it on multiple vehicles.
Old Oct 12, 2017 | 06:28 PM
Its good to be passionate like that.
If Harvey Wienstien's dates would have spoken up like that, we would not have all 27 of them coming out on one day.
