SDD Software
Old Dec 29, 2022 | 12:00 PM
  #41
wymjym's Avatar
Originally Posted by Sean W
Thx Ed! I recall they were able to use Autologic to enable Aux and it seemed to be able to handle the CCF file. Still a lot of $ for a DIY tool so finding an Indy would be a way to go.
any idea which autologic they used for these advanced functions?
wj
Old Dec 29, 2022 | 02:23 PM
  #42
Sean W's Avatar
wj
Not certain as it wasn't me, but assume it would be the Opus AssistPlus or the Drive Pro
Old Dec 29, 2022 | 02:32 PM
  #43
Cee Jay's Avatar
Autologic..... that's like a $4000 option.
Old Dec 29, 2022 | 03:45 PM
  #44
wymjym's Avatar
For some reason I was hoping it cost less that the sdd option everyone fights with, oh well.
wj
Old Dec 29, 2022 | 05:45 PM
  #45
arenaej's Avatar
wj
My understanding is that Autologic was created by a group of disgruntled Jaguar technicians that wanted something better than SDD and it is. It’s priced for independent shops, not diy owners. Two independent shops near me have it, complain about the price, but use it every day.
Old Dec 30, 2022 | 06:39 PM
  #46
Colt23's Avatar
Hi Sean,
I’ve just started serious looking into getting SDD for my 07 XKR and seen this thread. Seeing as I have the some year of car would your modified version of the software be suitable and would you be so kind as to provide a copy of this.
Colt.
Old Jan 1, 2023 | 03:11 PM
  #47
110reef's Avatar
Originally Posted by panthera999
Also, below is a screen cap of the service function of the Autel AT200. You can see the seat recalibration there. TPMS is also on the next screen up. I've almost stopped using my SDD 150 in favor of this tool. Remember, some of the service routines work only on the 5.0 series (injector calibration, for example), some work on all. Yes, there's stuff on SDD that's still useful, but this gets the most common items. Cheap at $70 -- works with IoS and Droid.
So, it seems to be able to read these modules but not program them
Old Jan 4, 2023 | 07:07 PM
  #48
panthera999's Avatar
They're for testing purposes. I very much doubt new code could be loaded, but that's not their purpose.
They do trigger a resident controller routine, enabling a test or an adjustment. The lights routine, the CATS tests and adjustments, the seat and window recalibration. And so on.
SDD is still how a new module would be installed, or a new software release would be installed -- though I doubt there's anything new after 8-15 years.
Still, for $70 you get fast solutions and tests, rather than SDD's many hours of learning misery and gawdawfully bad user interface.
Not to mention a hundred+ test and data points that are actually easy to find and use.
Old Jan 6, 2023 | 02:45 PM
  #49
JagV8's Avatar
I've not used it but I like the sound of it & the price. Sounds worth trying.
Old Jan 6, 2023 | 03:35 PM
  #50
Cee Jay's Avatar
If you only want to read stuff, just get a cheap Bluetooth OBD2 dongle and the free Torque app. There's a crap-ton of info and the price is like $10.
Old Jan 7, 2023 | 04:17 AM
  #51
JagV8's Avatar
Definitely - except the title & contents of the thread made me think a lot more is wanted.
Old Jan 7, 2023 | 12:23 PM
  #52
110reef's Avatar
I did manage to reprogram the seats yesterday with it, so that by itself was worth the price of it to me. The passenger seat was nearly unusable, and now it is perfect! Thanks!
I will return my DA dongle and get my $350 back.
I will look into Mongoose, they supply software and dongle. Not sure of the price though.
Old Jan 7, 2023 | 12:50 PM
  #53
Cee Jay's Avatar
You got totally scammed at $350, they are $200 directly from the manufacturer website.
Also, be VERY careful with Mongoose/Mangoose cables as they are very often poor copies and can blow stuff up.
Directly from a Clone Mongoose page....
Please note:No Internet Connecting, Or it will make damage to JLR Mangoose!!! Computer System Requires: Win 7 and Win XP
Notice :
1.No Internet Connecting, Or it will make damage to JLR Mongoose!!!
2.Computer System Requires: Win7 and Windows XP
Old Jan 7, 2023 | 07:24 PM
  #54
Glad to hear it. I've used it to test a failing light system, among other things. Enabled me to repeat the test until I found a badly adjusted height sensor. Low cost, and does enough to make it worthwhile. And of course reads JLR codes across my controllers.
I've used Mangoose without problems. But then, I only use SDD 150 once in a long while, replacing 90% of my SDD diagnostic time with the Autel. Both have their uses. Some are weak. Neither does a great job with the ZF transmission, for example. But between them, they do quite a bit.
Old Jan 9, 2023 | 06:12 PM
  #55
110reef's Avatar
So it looks like shipping to return my DA dongle is $130. So does anyone in the states want to buy one? I can make you a good deal!
Old Feb 23, 2023 | 02:54 PM
  #56
110reef's Avatar
I did get SDD downloaded. I kept my dongle. However, I do not have a sign-on to SDD, so it is all for naught. So frustrating!
Any help would be appreciated.
Old Feb 23, 2023 | 06:45 PM
  #57
xalty's Avatar
crack
Old Feb 23, 2023 | 08:30 PM
  #58
Cee Jay's Avatar
The newer versions of SDD need a subscription through Topix, on a monthly basis or by year. It's quite expensive, really.
Earlier versions are self-contained and do not 'need' an internet connection.
Old Feb 27, 2023 | 04:19 PM
  #59
james5's Avatar
Hi
I was on a v161 version until recently without internet but the features are very limited. I heard about a key generator or code to use the Mongoosepro with the SDD jlr with more advanced functions. If anyone has any idea or knows anything about it please let me know.
Old Feb 27, 2023 | 04:57 PM
  #60
I believe the last version that doesn't need Topix is V150. But for most stuff, earlier versions are fine. V131 is pretty common.
I have both V150 and V131. Not clear to me if there are new files in V150 compared to earlier versions -- after V150 switches to "previous versions" based on the VIN it seems almost the same tool.
I'd love to know if there are upgraded files in V150 that would improve modules in the X150. Better head menu interfaces would be welcome....
BLKJAG702
Sep 26, 2020 05:30 PM
meirion1
Jan 31, 2016 10:07 AM
Joedotcom
Apr 10, 2015 07:28 AM
bookman
Dec 29, 2014 11:03 AM
Lagonia
Jan 12, 2014 07:26 AM
