smart key battery
Old Aug 11, 2016 | 02:29 PM
fishbait1's Avatar
Default smart key battery
how long should they last? car prompted me that the battery was low and it was new just 30 days ago.
Old Aug 11, 2016 | 03:55 PM
kj07xk's Avatar
Depends on how good the battery was to start with (brand name, or off-brand?), how long was it sitting before you put it in the remote, and how often you use it.
I know that my 3 presses to open the top while I'm approaching the car, and 3 to close it as I walk away, puts more drain on the remote battery than if I were to not do that.
I've been on the same battery for over a year, but I don't drive the car every day, and not at all in the winter, so I'd expect it to last longer than a daily driver.
Even so, I've noticed my range from the car for my top opening 'trick' has gotten shorter, and I should consider replacing it before it actually dies on me.
Old Aug 11, 2016 | 05:24 PM
Cee Jay's Avatar
My car's a 2010, has the original batteries from new.
Old Aug 11, 2016 | 08:12 PM
fishbait1's Avatar
3 presses to open or close the top? what is that? what do you press?
Old Aug 11, 2016 | 09:13 PM
Stuart S's Avatar
kj07xk's signature shows that he has the Jag Wragler's (a.k.a. WhiteXKR) remote control top kit that enables you to open and close the top with your key fob, as well open and close the rear windows with the top down. Search this forum for details. I installed it on my XKR - it's what the factory forgot.
One other thing - keep a spare CR2032 battery in your glove box.
Old Aug 11, 2016 | 09:25 PM
kj07xk's Avatar
Old Aug 11, 2016 | 09:43 PM
WhiteXKR's Avatar
See
I am always happy to answer any questions about the product.
Old Aug 12, 2016 | 03:42 AM
I replaced the batteries in both my smartkeys when I got my XK approaching three years ago. No problems with either of them since.
The rapid rate of discharge on yours suggests one or more of the buttons could be sticking.
Given the low cost of batteries, it's probably a sensible precaution to add replacement to the annual service tasks.
Old Aug 12, 2016 | 06:56 AM
WhiteXKR's Avatar
I would suggest trying a new, brand name battery. If it still dies in a month, you might try opening the fob up and swabbing the circuit board thoroughly with a q-tip and isopropyl alcohol. Then let it dry completely. This should help resolve a sticky switch or a parasitic leakage path (which could be due to flux contamination during manufacture).
I am still on the original battery on mine, and I must have used the fob many, many thousands of times during development and testing of the remote top!
Old Aug 12, 2016 | 07:46 AM
Stuart S's Avatar
+1. If you buy batteries locally, instead of from Amazon or other internet seller, you can check the expiration date on the package to make sure that you're not getting old stock. Low priced internet batteries are no bargain if they don't last.
Buyer beware - lots of fake watch batteries on the internet http://www.microbattery.com/counterf...atch-batteries
Old Aug 12, 2016 | 08:22 AM
fishbait1's Avatar
Buyer beware - lots of fake watch batteries on the internet Counterfeit SONY Watch and Coin Cell Batteries
Energizer battery, exp date 2024. not internet ( I know better).
went out this morning and am not getting the prompt now. might be I need to clean the circuit board as suggested. also will get some spares to keep in the glove box.
Old Aug 12, 2016 | 10:28 PM
ralphwg's Avatar
Just so you know, you can also raise and lower the top by using the lock button on your XK's doors. I now raise the top by pressing the lock button on the door three times when i want to raise it. Less usage on the battery. On occasion I also use it to lower the top.
Old Aug 12, 2016 | 10:44 PM
fishbait1's Avatar
mine won't, just tried it.
Old Aug 13, 2016 | 02:18 AM
kj07xk's Avatar
It's a feature of theJagWrangler Remote Top Control. You gotta get one!
Old Aug 13, 2016 | 04:17 PM
fishbait1's Avatar
ok, did it again today. replaced with another battery and now it won't work at all. any suggestions?
Old Aug 13, 2016 | 06:40 PM
jagtoes's Avatar
CHeck to make sure you didn't put the battery in upside down.
Old Aug 13, 2016 | 06:54 PM
Stuart S's Avatar
If you have 2 remotes and #1 doesn't work and the other one (#2) works, swap the batteries making sure that the polarity is correct. If the "bad" one (#1) still doesn't work, you know that the problem isn't the battery. Possible causes include not making good contact with the battery, a bad circuit, or corrupted programming. Try cleaning it as WhiteXKR suggested. If that doesn't work, it's time for the dealer to check it.
Old Aug 13, 2016 | 10:16 PM
fishbait1's Avatar
taking it to the dealer tuesday
curtizb
May 27, 2016 02:12 AM
AnD3rew
May 24, 2016 06:31 PM
WinterJag
May 17, 2016 02:36 PM
GordoCatCar
May 14, 2016 03:44 PM
flyc2c
US Lower Atlantic
May 14, 2016 11:00 AM
