Strange cable in right foot well
Old Jun 22, 2021 | 05:27 PM
Andwell's Avatar
Default Strange cable in right foot well
2008 xk. While working on the sound panel in the passenger's foot well, I found a strange looped stainless steel cable. It is very close to the foot well light. The cable has a very sturdy crimp where it loops back on itself. It is clearly made to be pulled on. I was very tempted to pull on it to see what it was for, but, I didn't pull. I was told a long time ago, that if you didn't know what something did, don't mess with it. Can anybody tell me what this cable is for?
Old Jun 22, 2021 | 09:41 PM
peterv8's Avatar
More details needed, which way does the cable go? Picture might help to identify.
Old Jun 23, 2021 | 06:38 AM
guy's Avatar
guy
True enough. However the only cable in the vicinity that I’m aware of is for the glove box.
Old Jun 24, 2021 | 06:20 AM
Bill Mack's Avatar
Does your glovebox open slowly or drop suddenly? If the latter, I am with Guy...the cable probably detached from the glovebox door arm.
Old Jun 24, 2021 | 06:42 PM
u102768's Avatar
The glove box uses a thread, not a cable.
Old Jun 25, 2021 | 01:29 AM
peterv8's Avatar
I get so frusterated with people starting a thread then dissapear!? Two days ago since he posted and no responce
on our reply's! If I had a problem and posted I'd keep an eye on the thread and answer asap!
Old Jun 25, 2021 | 04:46 AM
Bill Mack's Avatar
I guess you can call it a thread, but to me it's quite a bit thicker - see photo below (the captions are mine and were added to the photo that I posted in another thread).
As to the OP's question, what he can see may not be related to the glovebox, since he says it's stainless steel and the cable/thread below is clearly not. Might Jaguar have used stainless steel in the 2008 XK glovebox damper? Could be, but it seems like overkill.
The best next step would be for the OP to investigate further and provide pictures.
Old Jun 25, 2021 | 04:48 AM
Jack ZNZ's Avatar
Default Strange cabel belongs to the glove box damper
It is not right. The glove box door usees a cable for connection with the glove box damper. I know the problem. The answer above from Bill Mack is true.
Old Jun 25, 2021 | 08:06 AM
guy's Avatar
guy
it may be a pull cord for the optional parachute
Old Jun 25, 2021 | 09:17 AM
Cee Jay's Avatar
Evidently this thread will be utterly useless unless there is at least a picture of the offending cable and its location.
Old Jun 25, 2021 | 07:30 PM
u102768's Avatar
Chord is probably a better description but from memory it winds tightly inside a sprung cylinder so a metal cable wouldn't be pliable enough.
I have had to repair two and took pictures last time. This is what the one on my 5 litre looked like. It doesn't have the wound cable look that something like a bicycle brake cable has.
Regardless, it should be no where near the foot well light because it is on the opposite side of the glove box.
As Cee Jay said, a photo of the offending cable would be useful.
Old Jun 26, 2021 | 05:35 AM
peterv8's Avatar
The OP doesn't seem to be very interested in his problem!:-D
jagstuart
Sep 13, 2018 09:53 AM
Elkulichi916
May 13, 2017 06:52 PM
kennyjd
Mar 19, 2016 03:06 AM
lostpinky
Oct 7, 2010 08:02 PM
