Strange chirping noise coming from the dash...
Old Jan 23, 2024 | 07:07 AM
George Abitbol's Avatar
Question Strange chirping noise coming from the dash when driving...
Hi guys,
Well, the title kinda sums it up...but I'd add that I can only hear that (fairly discrete, still) chirping-like noise when I drive above a certain speed. Not at idle.
My guess is it's the AC fan getting a bit squeeky but I could be mistaken...have you experienced something like this?
And is it something one can fix oneself? And if not, for how much does that go in Jag dealership?
Thanks for the info!
Old Jan 23, 2024 | 07:54 AM
RichardS's Avatar
Try turning the speed of the fan up and down and see of that affects the noise. Listen under the bonnet just to check that it's not originating from the engine. It could be the little cabin air temp sensor fan in the lower dashboard but you would probably hear that at idle as well.
Richard
Old Jan 23, 2024 | 09:44 AM
Sean W's Avatar
It's likely it isn't the aspirator given that it runs at a constant speed, regardless of engine speed, but it's still worth looking into because it's commonly described as a chirping noise behind the dash.
Old Jan 23, 2024 | 09:52 AM
And I should add it seems to be coming from the middle, behind the center console.
So, although I could be mistaken, it would surprise me if it actually was the aspirator.
What leads me to think it's the AC fan is because this noise comes above a certain driving speed, as if the incoming air was sufficient to disturb a smooth spinning, dunno...
Old Jan 23, 2024 | 01:49 PM
RichardS's Avatar
I'm not sure what you mean by the AC fan? There is a fan in the centre console which creates air flow through the cabin vents and up to the windscreen but it is normally known as the heater fan or blower as it blows both hot air and cold air.
Richard
Old Jan 23, 2024 | 03:12 PM
Richard
Yeah that's what I'm talking about. Sorry but English is not my native language, so even if I'm quite comfortable with it, sometimes I miss the mark...
Sean W's Avatar
Richard
That blower motor is behind the glove box at the top of the passenger footwell and wouldn't change with vehicle speed.
Old Jan 23, 2024 | 04:09 PM
RichardS's Avatar
I'm inclined to agree so covered that in my post #2.
Richard
Old Jul 20, 2024 | 04:20 PM
nateb26's Avatar
any solution to this? is there another fan behind the center console/infotainment system?
Old Jul 20, 2024 | 08:32 PM
McJag222's Avatar
Depends where the noise is coming from - some members have had noise issues with motor in the humidity sensor - cleaning it out has helped:
Check this post out:
https://www.jaguarforums.com/forum/x...-noise-162863/
RileyRomius
Jun 30, 2023 11:20 AM
TheFrenchJag
May 28, 2020 12:51 PM
James Lewis
27
Aug 22, 2013 06:06 PM
agentorange
Dec 7, 2011 04:05 PM
