Tempermental Fluids
Old Jun 26, 2022 | 04:11 PM
Scott in PA's Avatar
Default Tempermental Fluids
My engine and coolant had a huge fight. The coolant stormed out just as the wife and I were about to attend a Pittsburgh Symphony concert.
Old Jun 26, 2022 | 04:14 PM
NBCat's Avatar
The outlet hoses to the EGR valve are known failure points as is the water outlet containing the thermostat.
Old Jun 26, 2022 | 07:12 PM
lear60man's Avatar
I had a pipe go South just s I pulled into my driveway once on my old RR. I took it as a win not being stranded.
Old Jun 28, 2022 | 06:43 AM
The culprit was the radiator fan controller.... stopped working, so when we arrived in Pittsburgh and had to sit in traffic the temperature started to rise. Part readily available!
Old Jun 28, 2022 | 07:14 AM
V7Sport's Avatar
Glad you found the problem. But where did the puddle in your picture come from? Was there a hose failure as well?
Old Jun 28, 2022 | 05:25 PM
The problem didn't manifest until we got downtown and hit city traffic. Sitting negated any cooling effect from driving, so the coolant boiled over...it must have got pretty hot to lose that much.
Old Jun 28, 2022 | 06:32 PM
NBCat's Avatar
Use a smart phone with the Torque app to connect the vehicle's PCM via the OBD port using a Bluetooth interface. You can then monitor the coolant temperature in real time since there's no gauge on the instrument cluster.
Something else you can do to help prolong the life of the plastic cooling system parts is to leave the bonnet open, or at least unlatched whilst parked to let the hot air escape quickly. Even though the XKR has bonnet louvres, hot air gets trapped along the cowl.
Old Jun 29, 2022 | 07:37 AM
panthera999's Avatar
Scott -- you mention a fan controller. Was there a separate one, or did they do the entire fan assembly?
Panthera
Old Jul 3, 2022 | 05:10 PM
My mechanic listed it on my invoice as the radiator fan assembly for $1535.00
Old Jul 4, 2022 | 08:18 AM
jahummer's Avatar
Certain there’s no issue with either water pump in the circuit? I’ve had fans fail but never have had a boil over.
Old Jul 4, 2022 | 08:19 AM
jahummer's Avatar
Panthera
It’s built into the assembly.
rf69
28
Jan 29, 2021 05:33 AM
Kooper
Jan 16, 2018 09:18 PM
Ish
Apr 8, 2014 04:51 PM
ShaneIam
Jul 9, 2012 10:14 PM
RichmondXK
Mar 19, 2011 02:42 PM
