Trickle charging outside
@Woo5ie , a TVR Chimaera 4.0 V8!! Fun!
@RichardS , I can't disagree with you, of course. Though we should educate some in recognizing that the quiescent drain on a 2006+ XK is rated at <35mA. That is 35 thousands of an amp! If the battery is 90Ah, 800 CCA... its going to take a lot longer than 30 days to drain!
In the workshop manual, section 4.2, it clearly states that batteries should be tested at 30 day intervals and charged at 90 day intervals, with the expectation and assumption that a sound battery is installed.
Not to mention that in some regions of the world, if you are parking on the street for 90 days... I'd be surprised if the wheels were still on it, which could negate the need for a battery, anyways.
And truly, there are periods within the calendar year that my vehicles sit for months on end, without issue.
So, back to 'what to do'. Fix the root issue or ignore it and play the charging game. We all have different approaches to this.
Cheers to all... global warming has afforded me a day of spring skiing ... in Feb! See ya!
Richard
Well, yeah, running 12VDC outside is a much better choice.
Grab any AC cord, cut the ends off, and attach them inline with the 12V wires. AC cords are marked Hot and Neutral with ridges along the Neutral insulation. That'd be for the DC negative side. Of course, I'm not sure about Brit stuff.
For a given resistance of cable, the voltage drop is proportional to the current squared, so it's beneficial to keep the current low. This is why the mains supply is high voltage cross-country; 115kV in the UK on the pylons (often). AC is used, incidentally, so the voltage can be easily adjusted using a transformer (which don't work on DC).
Running 12 volts over a fairly long cable is not such a good idea since the effects of voltage drop will be more marked (lower voltage and a higher current) than with either 115 or 240 volts where the voltage is high but the current is very low.
