UK MOT advisories
Old Dec 10, 2017 | 05:39 PM
Tania Thomas's Avatar
Default UK MOT advisories
Hi everyone....first post, go easy on me.
I'm researching a few local XK's and doing my homework on the DVLA site with past MOT's.
I see every single one coming through with an advisory that because of some under-body sheilding, that there are components within the test that they're unable to access, hence they must have skipped those and carried on.
What exactly is being missed and are those things going to bite someone on the backside one day, years on?
What is this shield covering??
Old Dec 10, 2017 | 06:00 PM
jagtoes's Avatar
The covers/shields are part of the cars aerodynamics . It is a large plastic shield that covers the bottom end of the engine from the nose to the transmission. With it on you can't see if there are any fluid leaks or damage to the underside of the engine compartment. These shields are screwed on and are removable . There should be no reason why they can't be removed for any inspection unless the inspectors are to lazy to do it or afraid they will damage something. It can be done .
Old Dec 10, 2017 | 06:06 PM
If they're that large and cover that volume of the underside, they'd cover quite a lot.
I'd almost be 99.9% certain in saying that the UK test would prevent any kind of removal of parts to gain access, but certainly would be interested to know what they'd want to have a look at. If it was a critical 'must check' item, then the test would naturally fail, but as it pops up as an 'advisory' then i'm thinking its not something that critical.
Maybe any of the UK readers here can help?
Old Dec 10, 2017 | 06:54 PM
NBCat's Avatar
What components did they give an 'advisory' on? I do remember my Morris Mini failing the MoT for a small oil leak, but that was years ago.
Old Dec 10, 2017 | 07:05 PM
They don't, thats the quandary...the standard quote used always is along the lines of "certain items unable to be checked because of engine cover"
Old Dec 10, 2017 | 07:11 PM
NBCat's Avatar
Did you make an enquiry as to what the 'certain items' are? Do DVLA have a list of items that are checked during the MoT inspection? I remember the garage having a list they could use to tick off each area.
Old Dec 10, 2017 | 07:15 PM
NBCat's Avatar
Have a read here:
https://www.gov.uk/government/public...cked-at-an-mot
Old Dec 10, 2017 | 07:41 PM
Ranchero50's Avatar
I think the little one that covers the front bottom of the engine is blocking access from leak inspections. I tossed mine in the corner hoping it would help with cooling.
Old Dec 11, 2017 | 02:30 AM
JagV8's Avatar
They are not allowed to remove things but also there simply isn't time as there is a max price and I doubt they make money as it is. The MoT is very thorough within its limitations and has transformed Britain's car fleet. (But is by no means perfect - we need to work on drivers!!)
Nowadays many cars have shields etc so many are getting these advisories.
It would make sense to remove various things (sill covers etc) when buying but that is not an MoT issue (yet?).
The engine shield doesn't tend to be hiding anything but others may be on non-aluminium cars.
An MoT is not a guarantee that a car is worth buying and does have limitations but short of a massive strip-down (and huge hike in price) that is not going to change.
Perhaps they will start using borescopes (thin cameras) to inspect a bit better - you could DIY that.
Old Dec 11, 2017 | 09:44 AM
8bit's Avatar
As above, the MOT testers are forbidden from undoing or removing anything to inspect the car. It is a visual check only, except for the emissions tests, any applicable braking force tests and checks for things like lights illuminating when they should, horn, windscreen wipers etc.
That being said, I've never seen an advisory on my own car for the undertray preventing any inspection so I presumed it was because the undertray did not obscure any of the things they have to check. It won't have prevented them from inspecting the brake lines or anything like that, just might mean that they couldn't see if there was anything looking unacceptably worn or leaking fluids, for example.
If you want a more thorough check carried out, some dealers will do a visual health-check on a car for a small fee or free of charge; if the car in question is being sold privately then I guess it would tell you a lot if the seller is happy to have the car inspected. The AA, RAC and other third parties also offer such checks if you want a little more peace of mind.
littlelic69
Feb 5, 2014 02:56 PM
JimC64
Non-Jaguar Vehicles
Mar 5, 2011 07:07 PM
BadCat
Feb 2, 2011 03:29 AM
chiller1
Jan 18, 2009 07:32 AM
