VelocityAP AJ34S 4.2 XKR Dyno tune
Old Sep 30, 2019 | 09:52 AM
  #81
SinF's Avatar
If I learned anything from this thread, is that I was not paranoid when I suspected that oil consumption was linked to engine tuning. Now, if Cambo or VAP or anyone else posts reasons for this, the community will have a lot less dead cats.
Old Sep 30, 2019 | 09:56 AM
  #82
MoscowLeaper's Avatar
For a AJ133/AJ126 it's not a tuning related issue, it's a JLR's flaw.
Old Sep 30, 2019 | 10:06 AM
  #83
SinF's Avatar
Do you know if it affects all AJ133/AJ126 or only certain years?
Old Sep 30, 2019 | 12:31 PM
  #84
Stuart S's Avatar
This 2017 F-Type R with only 4,400 miles is for sale on the Forum Marketplace because it has a blown engine. It was extensively modified by the original owner in Miami and it appears that warranty coverage was denied because of an aftermarket pulley and tune.
Anyone know the identity of the tuner and details of what happened? No reply from the owner.
https://www.jaguarforums.com/forum/market/219811
Old Sep 30, 2019 | 06:52 PM
  #85
JagRag's Avatar
That's the JVIII debacle!
Two threads with all the history on it.
Old Sep 30, 2019 | 07:41 PM
  #86
OzXFR's Avatar
Hey Nick, do you have any advice or tips on simple steps owners can take to minimise the risk of this issue occurring?
I understand the issue is excessive oil use which can result in catastrophic engine damage if the oil level is allowed to get too low.
I had a 2010 XFR for a couple of years (with an XKR-S tune put on it by you & Cambo) and I currently have a 2014 F-Type V6S that I have owned for the last three years, and neither car has ever used any oil. And I mean zero measurable, the oil level read-out has never varied from "max". Also I have always used 5W-20 oil and never used 0W-20, and I change the oil and filter every six months which for me works out around 3,000 miles.
I use 5W-20 because it is a lot cheaper here than 0W-20 and it's a "hot climate" here where it often gets to 110 F but rarely drops below 32 F.
Should I keep using 5W-20 or switch to 0W-20 or would that make no difference to the issue in question?
What about oil and filter changes, does changing every 3,000 or so miles help or make no difference?
Like many here I would like to know exactly what the inbuilt JLR flaw is but I understand if you don't want to make it public.
Old Sep 30, 2019 | 10:05 PM
  #87
jahummer's Avatar
Meanwhile back to my thread, I adjusted my signature...sadly the limit on characters has caused me to truncate quite a few modifications the car...to reflect the "at the wheels" increase. Per DynoJet/WinPep 8, the differential between stock baseline and Old Jaguar re-map increase at the wheels was over 50 horse power and the torque increase at the wheels was over 90. I don't know what that translates to in crank numbers but regardless VAP's tune managed no more than a rear wheel differential increase of 25 HP and 40 TQ over baseline which was a lot less than was promised prior to purchase.
EDIT: I meant to mention I have another JLR vehicle with the 5.0 litre supercharged 500+ stock HP motor and the 4.2 re-mapped car feels pretty damn near as powerful. For comparison, flashing back to the base factory map makes the car feel like the 2008 N/A 4.2 X150 I had!
Old Oct 1, 2019 | 02:46 AM
  #88
All engines/model years are affected
Old Oct 1, 2019 | 02:48 AM
  #89
Not only an excessive oil use, but a lack of oil level monitoring. If it shows max - it MAY BE not actual max, that's all i can say.
I prefer 0w20 castrol (especially since im still running on an original, older style tensioners) and maximum oil service interval of 6000km.
Old Oct 18, 2019 | 04:42 PM
  #90
trkyam's Avatar
I still need a tune,
I'm thinking about buying a Kess V2 to read/write as I want the ability to go back to stock.
I first inquired with Cambo about a year ago, but hes not replying to me anymore..
I need the ability to go back to stock on my own.
Old Dec 21, 2021 | 05:24 AM
  #91
Outrun's Avatar
Moscow Leaper, might you have a tune for what was a 4.2 with a top pulley,200 cell cats and the engine being re-sleeved out to 4.7 litres ?
Old Apr 1, 2023 | 04:09 AM
  #92
Kyle_rs's Avatar
Wow... That was a spicy read!
Old Nov 5, 2025 | 09:11 PM
  #93
Street cat's Avatar
Originally Posted by Mufc
So Cambo / Moscowleaper. / Alexjag. If I was to purchase one of your tunes each for my stock XKR-S what HP and Torque gains should I expect. I would be more than happy to run a baseline with a stock tune, then both of yours back to back on the same dyno on the same day and post the results on the forum.
Any takers
did this ever happen?
Old Nov 29, 2025 | 06:53 PM
  #94
AlexJag's Avatar
Sponsor
I don't drive my 4.2 much if any but it's a dyno that was done a long time ago check out a lot of racing videos too for that same car
rfr66
Oct 1, 2019 09:00 PM
patrickw813
Nov 7, 2015 12:26 AM
patrickw813
Oct 26, 2015 10:06 AM
BostonKiller
Sep 2, 2015 01:18 AM
WaltB
Oct 5, 2014 10:46 PM
