Weird Whoopee Cushion Sound (Seriously)
Old Oct 19, 2019 | 01:18 PM
Reverend Sam's Avatar
Default Weird Whoopee Cushion Sound (Seriously)
I few weeks after I got my XKR I had to stop in a parking lot to sit in on a conference call. It was about 95 degrees out so I left the engine running as I listened in on the call. After about ten minutes I heard what sounded like a truck's Jake Brake, or a very low whoopee cushion, from the right rear of the car. At first I thought it was actually a truck. Then it happened again a few minutes later. And again. It would happen every five to ten minutes. It had to happen about 3 or 4 times before I finally realized it was coming from my car.
Now, every time I stop and let it idle for ten minutes or so, I'll hear that sound. What could it be? It's obviously coming from the right rear. My wife heard it and she thought it was a truck. She also said it was from the right rear.
It basically sounds like a very low fart that last about one to two seconds and gets lower and quieter with time.
I was thinking that maybe it has something to do with the fuel system pressurization, like a relief valve or something, but I never smell gas fumes, so... Any thoughts?
Old Oct 19, 2019 | 01:24 PM
Cee Jay's Avatar
Hey, a new problem! Never heard anything about this before, ever.
I eagerly await any worthwhile responses, since this post of mine is utterly worthless.
Old Oct 19, 2019 | 01:25 PM
George05's Avatar
Really cant think Rev sam , hope others can help
Old Oct 19, 2019 | 01:26 PM
I can't tell if you're being serious, or telling me I should have used the search feature. ¯\_(ツ)_/¯
Old Oct 19, 2019 | 01:59 PM
TexasTraveler's Avatar
Just throwing it out there but could it be some of the electronics in the right rear, ie nav unit ect. making noises
Old Oct 19, 2019 | 02:17 PM
George05's Avatar
Cats having a fart lol
Old Oct 19, 2019 | 03:08 PM
kj07xk's Avatar
Well, the XKR has a vacuum pump and tank for the active exhaust operation, but I thought that was on the left rear, behind the wheel, but I could be wrong, I only have an XK.
Old Oct 19, 2019 | 03:19 PM
George05's Avatar
Top man , could be that
Old Oct 19, 2019 | 04:06 PM
This is definitely coming from the right side, and it's muffled, like it coming from outside of the car. At least that was my first thought. I told a friend about it. He knows nothing about Jags. At all. He immediately said "duck valve". I was like "WTF???" I had never heard the word duck used in relation to cars until I got my XKR, and now I've heard it in reference to two different things. I googled "duck valve" and found out it's actually called a duck bill valve, and that's what is used on the AC drain. But the sound I'm hearing is obviously not the AC drain.
Tomorrow I might put a microphone on the back right side, let the car idle, and see if I can get a recording of it.
Old Oct 19, 2019 | 04:15 PM
By the way... if anyone here listens to Glenn Beck, at the end of each segment when he's cutting to commercials he plays an almost identical sound. It's mixed in with the outro music. Right at the end, a moment before he cuts to the commercial, there's a very low "BRRRRRR". That's the sound I hear. But I hear it even when the radio is turned off.
Old Oct 19, 2019 | 04:53 PM
George05's Avatar
Yeah try take a recording . sure most duck bill issues were with the 4.2 l cars but cant be certain if the 5l cars are affected
Old Oct 19, 2019 | 07:40 PM
Sean W's Avatar
I'm no help Rev Sam. I looked up the modules in the right rear. Other than the Nav Module, the Fuel pump driver module is down near the evaporation canister but have no idea if it makes noise (rattling in a bracket)?
Heck I had to Google Glen Beck.
Old Oct 19, 2019 | 08:54 PM
WhiteXKR's Avatar
Can't say I ever heard it on mine, but the nav, module contains a DVD and from your description it sounds a bit like a DVD spin-up or spin-down.
Old Oct 19, 2019 | 09:00 PM
Stuart S's Avatar
Here's the source:
Old Oct 24, 2019 | 12:52 PM
Sean W's Avatar
How about an update Rev Sam? You had the road trip. Has it happened again?
Old Oct 24, 2019 | 06:38 PM
I only hear it when I'm sitting in a parking lot idling for 10 minutes or more. This past weekend was kinda busy. I'll try to get a recording of the sound this weekend. (No promises. I might have to golf or something.)
Old Oct 24, 2019 | 06:56 PM
Sean W's Avatar
Golf is Mandatory!
Old Oct 25, 2019 | 05:00 AM
old_dawg's Avatar
Just a suggestion from someone that knows nothing. The gas filler cap is in the right rear and the fuel system is closed as we get an message if we leave the cap off or not tight enough, But would guess it has to vent somehow.
v1rok
May 21, 2025 03:53 AM
davidcalgary
May 20, 2013 10:37 AM
qwiketz
17
Jan 18, 2012 01:09 PM
equicor
Jan 24, 2010 06:05 PM
