Well that's not good!
Old Mar 4, 2020 | 04:40 PM
71XKE007XK's Avatar
Default Well that's not good!
I had a previous post about a couple of issues with the new to me XK. Getting code P0852 and cruise not working.
Had a new battery installed today but both issues remain.
More troubling, I had a chance to finally open it up (just bought it last week). it completely cut out at 4500 RPM 's or so. Like sputtering and coughing so to speak. Tried again same result. Any ideas what would cause this? Car runs ands sounds great below 4K.
thanks for the responses
Old Mar 4, 2020 | 05:10 PM
guy's Avatar
guy
without codes, shooting from the hip. Clogged Cats?
P0852: gear shifter adjustment?
Old Mar 4, 2020 | 05:28 PM
71XKE007XK's Avatar
No codes at all except for the 0852 neutral safety switch voltage. First time at full throttle it kicked down a gear and then like huge misfire. Punched from a dead stop and above 4500 it cut out like that again. No codes or CEL.
Old Mar 4, 2020 | 08:41 PM
kj07xk's Avatar
Sounds like the rev limiter kicking in, but that should only happen in P and N. Weird.
Old Mar 4, 2020 | 10:30 PM
mhminnich's Avatar
That sounds a lot more like insufficient fuel supply. Start simple by changing the fuel filter. Read your fuel pressure and verify it is within limits.
Old Mar 5, 2020 | 12:02 PM
gkubrak's Avatar
Also check fuel pressure BEFORE replacing filter. That way you have a reference and can see if it made a difference.
Old Mar 5, 2020 | 12:23 PM
mhminnich's Avatar
Checking at idle is fine , but I'd be more interested with how the fuel pressure reacts
​ when he's under WOT.
Old Mar 5, 2020 | 12:30 PM
71XKE007XK's Avatar
It's definitely seems to be some type of limiter or management system. It's at 4500 on the nose when it cuts out. Tested with the paddles in multiple gears. Pulls like train up to that and sounds perfect.
if it was related to the pump and fuel pressure, wouldn't it be erratic when it misses or cuts out? It's like something is telling it to cut fuel at 4500. Strange. It's going to the dealer on Tuesday.
71XKE007XK
Mar 12, 2020 01:49 PM
Stephen Kuhn
Sep 22, 2019 09:59 PM
Ron Gillespie
Mar 31, 2019 04:34 AM
ferrytrip1
Sep 9, 2014 09:35 PM
DenverDDS
Mar 4, 2013 02:35 AM
