Changed key
Old Feb 29, 2020 | 03:12 PM
Canadacat's Avatar
Default Changed key
Fob batteries and now won't work.old battery was dl2032 new battery cr2032, won't even work with old battery now? Any suggestions ,it will plug in and start but no remote
Old Feb 29, 2020 | 03:21 PM
Cee Jay's Avatar
Dozens of reasons.
New battery worse than the old one.
Contacts on case don't touch battery well enough (loose prongs?) <--- Many complaints in these forums
Smart Key dead.
Okay, only a few.
Old Feb 29, 2020 | 04:36 PM
Canadacat's Avatar
Well the little tabs weren't making contact with the positive so I proceeded to bend them and then snap them off with my big clay fingers. Anyway s jammed a piece of foil under battery and got it at the right angle to make contact. A Flintstone fix but it's working.
Old Feb 29, 2020 | 06:47 PM
Cee Jay's Avatar
Hey, it works. Plus nobody can see it.
Old Feb 29, 2020 | 09:04 PM
Stuart S's Avatar
Don't risk bending the battery prongs and breaking them!
If the battery prongs have stretched, use a CR2035 battery instead of a CR2032. They're identical except that the CR2035 is 3mm thicker and will fill in the gap caused by the stretched prongs.
Keep a spare fob battery in your glove box for when the one in your key dies.
See my Post #14: https://www.jaguarforums.com/forum/x...orking-155914/
Old Feb 29, 2020 | 10:06 PM
Cee Jay's Avatar
Originally Posted by Stuart S
.................... use a CR2035 battery instead of a CR2032. They're identical except that the CR2035 is 3mm thicker and will fill in the gap caused by the stretched prongs...................
Decimal-three mm? The things are only 3.2mm to start.
Old Mar 1, 2020 | 03:58 AM
Stuart S's Avatar
Yep, you passed test! You must have read my Post #14 in the thread linked above. It's 0.3mm thicker, as I stated here:
Old Mar 1, 2020 | 07:44 AM
guy's Avatar
guy
And check the dates on the battery packaging! Been there.
And thanks to Stuart S, I have replaced all batteries in all fobs with CR2035 every spring. Little things like the proximity detection system not as responsive as it should be, annoy me.
Old Mar 1, 2020 | 08:34 AM
Stuart S's Avatar
Use your head! Hold your Smartkey fob to your forehead (or under your chin) and open your mouth to increase the range. Really, no kidding. Try it and you'll see.
https://driver-safety.wonderhowto.co...range-0139966/
Old Mar 1, 2020 | 09:00 AM
guy's Avatar
guy
Lmao!
perfect way to start a Sunday morning! Thanks Stuart!
Old Mar 1, 2020 | 11:21 AM
Cee Jay's Avatar
It's funny, but doing the Head Thing does work. It increases the range by up to 50%. Try it. I've never heard of the "Open your Mouth" part though.
Old Mar 2, 2020 | 07:23 AM
JagRag's Avatar
And at the same time increase your risk of getting brain-cancer/tumors.
Old Mar 2, 2020 | 12:50 PM
JagV8's Avatar
Also, make sure to keep your phone away from your body!!
Not very useful if you do, though...
Old Mar 4, 2020 | 09:21 AM
barnsie's Avatar
Surely your tinfoil hat affords you a good level of protection?
Old Mar 5, 2020 | 05:11 AM
1 of 19's Avatar
No I'm not trying that. Can you imagine your neighbors driving by as you stand there looking at your Jag with your mouth open and the fob on your forehead.
Old Mar 5, 2020 | 05:14 AM
1 of 19's Avatar
This is why I troll this site almost daily. Every now and then a nugget of information shows up. One even I can remember. Thanks Stuart S!
Old Mar 5, 2020 | 06:02 AM
guy's Avatar
guy
Yes buuuut, are we going to start a secret stance as unique as Monty Python’s Ministry of Silly Walks just to use the fob??
Old Mar 5, 2020 | 04:09 PM
Stuart S's Avatar
You can imagine the look on people's faces when they see a parked XKR and watch the convertible top go down and there's no one in the car! Then they look around and see this old guy about half a block away who looks lost and confused, with his hand on his forehead and his mouth wide open!
Thanks, WhiteXKR! That's Steve, the inventor of the remote control top.
carzaddict
Jun 3, 2019 05:50 PM
Watchgeek
Oct 18, 2011 06:17 AM
IrishXtype
Mar 18, 2011 06:51 AM
Stiffler4774
Jun 10, 2010 04:47 PM
Threwth
Mar 5, 2010 05:25 PM
