Well, well well.... Unicorn?
Old Jul 13, 2025 | 12:35 PM
Circumnavigator's Avatar
Default Well, well well.... Unicorn?
I am a firm believer in patience wins and when looking for something, you have to know when it is the right thing.
So, After seeing/driving the beat to death '10 XKR on Friday and walking away, I decided to slow my roll, watch BaT auctions here and there and wait for the 'right' one.
Low and behold, as always seems to happen (even meeting my wife which is another story), I end up talking to a guy.
Turns out his grandfather just passed and he inherited a 2007 XK vert. 50k miles.
As per usual, I asked if he knew if there were service records. He did not.
But the way he put it, "He had it since 2014 and more less liked to look at it than drive it."
The only issue he knows of is the rear window glue gave up at the top, so that would need to be repaired.
Had him send me a few pics. Interior looks pristine. Top looks pristine. Can't even see a scratch on the exterior.
Oh and did I mention, when he sent me the pics, there was a nice little R on the trunk lid opposite the XK?
Did I just find a unicorn??
Old Jul 13, 2025 | 12:38 PM
Cee Jay's Avatar
Vents in the bonnet? Or didn't you get a picture of the front?
The father of a friend of mine a long time ago went to check out a "mid-60s Chevrolet for sale" and it turned out to be a Corvette. Yeah, he bought it.
Old Jul 13, 2025 | 12:40 PM
Yes vents. And based on the pics, he wasn't kidding when he said grandpa never drove it.
I did ask for the sill pic. Not a portfolio. But I kinda knew that based on the color.
So if the car was very occasionally driven, doing worst case scenario, I have to think of the things that go wrong with age as opposed to use. Suspension? Anything rubber or plastic? Top mechanism? ??
Old Jul 13, 2025 | 12:45 PM
Cee Jay's Avatar
Anything normal for any 18 year old car.
Every fluid, probably every bushing and boot, probably paint correction if it hadn't been waxed, and if the top hasn't been down in a long time, maybe seals or even a cracked top fabric if it dried out. That's what may have ended the rear window seal.
Still though, I'd think it very worthy of a good look.
Old Jul 13, 2025 | 01:10 PM
Thanks. The top looks to be in really good shape. What threw me is the seats didn't even have the usual rub marks in one or two spots. They are flawless.
Figured I'd do a SC service, oil change, its nearing 60k so a transmission service regardless, given no records.
First real upgrade, assuming nothing else is wrong is to buy one of those "replace the plastic/rubber with aluminum" kits and do that myself.
Planning to go see it Friday/Saturday.
Old Jul 13, 2025 | 01:23 PM
Speedmaster's Avatar
Congrats on the find. Love it when the hunt is successful.
Old Jul 13, 2025 | 02:17 PM
…maybe seals or even a cracked top fabric if it dried out. That's what may have ended the rear window seal.
Correction to my earlier reply.
After coming into every square inch of the pics, the roof seems ok, but def aged.
Will have to budget in a new top ($3100 twill) into the price.
(see attached)
Separated window.
Separated window.
Can tell it is a bit old and worn.
Old Jul 13, 2025 | 03:27 PM
bocatrip's Avatar
Don't forget Duckbill, dash leather (especially around instrument cluster). All boots for suspension parts, battery, and cooling system for leaks.
Old Jul 14, 2025 | 09:12 AM
HealeyJag's Avatar
Default XKR
Great it's on your neighborhood!! SUSPENSION...time is your worse enemy..
Get a PPI and negotiate from there!
Old Jul 14, 2025 | 03:42 PM
jahummer's Avatar
If this is a 2007, there isn't a "kit" as this would be the 4.2 not 5.0 litre. I replied to one of your other threads yesterday with important points to consider...
Old Jul 14, 2025 | 04:01 PM
Yep, I pasted it into my master checklist. Thanks for that!
Old Jul 14, 2025 | 04:15 PM
Stuart S's Avatar
@Circumnavigator The color appears to be Radiance, with Caramel interior, one of my favorite color combinations. It's a 2007, which means it has a power antenna on the right rear fender. Make sure it works and goes up and down when you turn the radio on and off. That was eliminated in 2008, when the antenna was hidden inside the rear spoiler.
I doubt that you'll find a nicer XKR within driving distance.
Here's a similar 2007 XKR Convertible auction from BaT. It sold for $16,500 after not meeting the Seller's reserve.
https://bringatrailer.com/listing/20...onvertible-27/
Many have sold for less, but they needed work.
Good luck
Stuart
Old Jul 14, 2025 | 04:21 PM
Good luck
Stuart
Thanks Stuart, I'm hoping so.
Old Jul 14, 2025 | 08:55 PM
Stuart S's Avatar
@Circumnavigator Note the little box with the 👍at the bottom left of a post. There's no need to write a "Thank you" since by tapping that box you thank the author, which then gets added to the total number of "Likes" in the upper right corner of his posts.
Old Jul 16, 2025 | 03:23 PM
Update time.
Seller wasn't very responsive on marketplace. Finally provided the VIN so I ran a carfax. Confirms his grandfather owned it since 2014.
Then sent him a long summary of questions and he sent me his phone#.
We just chatted.
Grandpa died around a year ago. Grandma doesn't want it. Nobody else in the family wants it or knows what it is.
So seller took it to his cousin who works at a dealership, put in a new battery, buffed it up and he posted it.
Then it went back in the garage with a cover (tarp) over it. Told him not a good idea and I'd take the cover off. (paint swirls and humidity)
Said everything works fine last time they moved it around and he isn't sure it is 58k miles but it is between 54k and 60k.
I asked how long it has been sitting. He said a few weeks since last started.
I recommended he go start it up and let it run for a bit. Get the juices flowing and make sure battery is charged. (Told him the 12.6V)
Now to find a PPI place. Nothing but small rural shops within 30 miles. Did find a Toyota dealership....
I think I can grab this '07 50-something K mile xkr vert for about 12K from the chat. Which gives me the wiggle room for a new top ($3100 installed) and be around $15k total in.
Old Jul 16, 2025 | 03:25 PM
HealeyJag's Avatar
Update time.
We just chatted.
why haven't you gone to see it??
Old Jul 16, 2025 | 03:30 PM
Stuart S's Avatar
@Circumnavigator is from North Carolina, where it's still legal to procrastinate.
Old Jul 16, 2025 | 03:34 PM
I’m seeing it Friday. Yeesh some of us still work 9-5s ya know.
And haha Stuart that is true.
But lemme tell ya, in BFE trying to find a place to do a PPI is near impossible. Found a Toyota dealership 20m away. Fml. But gotta take what I can get.
Old Jul 16, 2025 | 03:50 PM
Here are the pics I have if anyone sees anything sketchy or questionable that I didn’t outside of the rear window.
Old Jul 16, 2025 | 04:37 PM
Cee Jay's Avatar
*SCARF*
