What did you do to your X150 today?
Old Nov 8, 2020 | 03:43 PM
  #1441
jon-izumi's Avatar
Fitted XKR-S spring damper units all round to resolve creaking rear shocks and original Jag front rotors to [hopefully] stop front brake squeal coming back again. Next job is to get 5-30w oil out of my 5.0 that a "specialist" indie put in.
Old Nov 8, 2020 | 04:28 PM
  #1442
Sean W's Avatar
Originally Posted by kj07xk
Ok, now that I’ve got those two gallons of corn squeezins, what do I do with those other nine gallons of waste?
Or you can just go here to find an ethanol station near you (US and Canada)
https://www.pure-gas.org
Old Nov 8, 2020 | 04:59 PM
  #1443
Cee Jay's Avatar
Originally Posted by jon-izumi
.................................... Next job is to get 5-30w oil out of my 5.0 that a "specialist" indie put in.
With my normal summer temps of 95-105F, I'll not use 0W-30, I'll stick with the 5W blend at least. Maybe even 10W dependent on season of projected oil changes.
Old Nov 8, 2020 | 06:52 PM
  #1444
jons's Avatar
Also had my shock out on the bench , the upper mount had separated and was causing a metallic sound on every bump (very similar sounding to a worn link rod)
there's some kind of ring-shaped foam insert in there, right? i think i found bits of mine on the garage floor the other day.
Old Nov 8, 2020 | 11:59 PM
  #1445
kj07xk's Avatar
Yep, exactly none near me (must be some Chicagoland area laws against it).
In WI, the city I travel to occasionally is listed, but the last time I checked, they no longer carry premium, just lower octane choices.
Old Nov 10, 2020 | 05:54 PM
  #1446
jon-izumi's Avatar
Definitely don't want to start an "oil thread" lo l, but I've been more concerned with having 30w in my 5 litre engine, I think I'm happy with 5w cold in Australian temps too.
Old Nov 12, 2020 | 12:59 PM
  #1447
jons's Avatar
today i uninstalled the muffler to see what an XK sounds like without one, and drove it around a bit.
ohh, it's good. it's very very good. startup and one delicate rev to 3k with letoff: https://streamable.com/rt0jzt
Old Nov 12, 2020 | 02:43 PM
  #1448
Cee Jay's Avatar
My muffler shop guy persuaded me to run mine when he had everything off to do the X-pipe.
It was fun; all crackly and loud.
Old Nov 12, 2020 | 04:34 PM
  #1449
jons's Avatar
i'm having a shop do a custom drop-in replacement for the stock muffler. told them i'd get around to taking it out to hear how it sounds, and then let him know from there. i went right back today with it still off and said just a couple glasspacks please! it just needs a little bit for those extra loud pops in sport/dynamic. shopping for another stock XK muffler now so that i can keep the tips and clamps exactly the same.
Old Nov 13, 2020 | 01:47 AM
  #1450
peterv8's Avatar
You need electric cutouts!:-D
Old Nov 18, 2020 | 11:14 AM
  #1451
dvdpsycho's Avatar
I bought a used XKR exhaust off of ebay and put that in with a XKR rear diffuser. I love the sound of the exhaust now.
Old Nov 18, 2020 | 11:55 AM
  #1452
007XKR's Avatar
Alignment after last weekend's rear suspension rebuild. Found a bunch of
Front end to follow after my checkbook recovers.
Old Nov 19, 2020 | 10:33 AM
  #1453
95 Cat's Avatar
Took it to the dealer for it's annual oil change. At least they washed it too.
Old Nov 21, 2020 | 01:20 PM
  #1454
MarkyUK's Avatar
Imagine what it's line in an R!?
Old Nov 25, 2020 | 08:13 AM
  #1455
V7Sport's Avatar
Default Hard reset with battery charger pigtail installation
Removed an in-vehicle battery maintainer that the previous owner had mounted above the navigation unit in the boot. This arrangement worked fine for topping up the battery but didn’t seem like a great idea should the maintainer have an electrical problem. Measured the unloaded battery voltage at 12.7 VDC 👍
I did a hard reset by touching the + and ground main battery cables together before installing a new battery charger pigtail for the external maintainer. Only resets needed on the car were the emergency brake per the dash message and the clock. Went for a nice morning test drive and found the transmission up and down shifts seemed smoother than before. I had also had a bit of a short shift from first to second when starting off which is gone now.
Life is good!😎
Old Nov 25, 2020 | 08:23 AM
  #1456
wsn03's Avatar
Life is good!😎
I'm interested in this. How did the hard reset work exactly? If you touched positive and negative terminals together there is no battery power so no electricity? I'm sure I'm being thick but I don't understand and would like to know what a hard reset is
Old Nov 25, 2020 | 08:47 AM
  #1457
007XKR's Avatar
Even when the battery is disconnected, some residual voltage can remain in the modules, wiring, etc. Touching the wires together, or simply positive to ground, will discharge that voltage, allowing the electronics to properly reset.
Old Nov 25, 2020 | 08:48 AM
  #1458
V7Sport's Avatar
+1
Old Nov 25, 2020 | 08:56 AM
  #1459
Sean W's Avatar
Quite simple actually. Our system has multiple modules and multiple capacitors. Holding the cables together allows to capacitors to discharge, thereby resetting.
From the electrical training manual:NOTE: A hard reset does not repair a fault condition. It simply brings all control modules back to their baseline condition. If a hard reset eliminates the symptoms, then further diagnosis is needed to determine the cause of the conditions, i.e. low battery causing a single control mod- ule to come off line temporarily.
Hard Reset Instructions
A ‘hard reset’ restores the control modules to their base conditions assuring that network communications are synchronized.
CAUTION:
Be sure to retrieve DTCs before disconnecting the battery.
All Vehicles except X105, X150
  • Disconnect the negative cable of the battery for at least 120 seconds
  • Reconnect the battery negative cable
  • Perform window initialization
    X105, X150 Vehicles
    Due to the window drop entry feature, the following pro- cedure should be followed to prevent door seal damage.
  • Open one window fully or open a door
  • Reset the window position memory for the passenger and driver door windows
    NOTE: If a hard reset is performed on a vehicle with a sunroof / roof opening panel and the roof is open at the time of the hard reset, the sunroof initialization proce- dure must be performed.
Old Nov 25, 2020 | 10:07 AM
  #1460
wsn03's Avatar
CAUTION:
    X105, X150 Vehicles
Thank you to everyone for your replies.
Q 1. How long do you hold the wires together
Q2. Is it a big sparks show?
