What did you do to your X150 today?
Old Jan 8, 2021 | 08:47 PM
  #1541
mhminnich's Avatar
And retain all its factory swirls
Absolutely not!! I took great pains to eliminate the swirls and scratches that came from the POs affinity for automatic car washes. Multi-stage polishing done with the right equipment and materials, patience, and attention to detail (paint correction to you youngsters) produces the same results
Old Jan 8, 2021 | 09:38 PM
  #1542
jahummer's Avatar
Proper paint correction breaks down each section of the car into a grid and grid by grid the paint is cleaned, decontaminated, compounded to remove imperfections and flaws in the paint and clear coat brought to a maximum gloss and then sealed. It is a process that can take a specialist several days to compete depending on the severity of the defects in the paint. This is a process done on new cars as well, not just older ones.
Old Jan 8, 2021 | 10:35 PM
  #1543
Cee Jay's Avatar
Yeah, that's what I did when I merely polished my cars.
Old Jan 8, 2021 | 10:50 PM
  #1544
gkubrak's Avatar
If it looks like crap, what needs correcting - the paint ... or the painter?
Old Jan 9, 2021 | 12:09 AM
  #1545
kj07xk's Avatar
Originally Posted by Bill Mack
Maybe it’s the lighting, but your whole front bumper cover appears to be lighter colored than the rest of the car?
Old Jan 9, 2021 | 04:32 AM
  #1546
Bill Mack's Avatar
You're right, it does seem that way - however, it's a trick of the light I think. Although it could be that the PPF has a slightly greater coefficient of reflectance than the uncoated parts of the car. It almost sounds like I know what I'm talking about!
Old Jan 9, 2021 | 08:08 AM
  #1547
kj07xk's Avatar
In your earlier post you said that the hood was also covered with PPF, so I’m surprised at the distinction between the two.
Old Jan 9, 2021 | 09:25 AM
  #1548
Bill Mack's Avatar
Here are a couple of pictures taken of the nose and hood area. I don't see any difference in the brightness of the reflection between the two.
Old Jan 9, 2021 | 10:26 AM
  #1549
Cabrio Bob's Avatar
Probably the cause is your camera. It is probably slightly sensitive to infrared light caused by a less effective internal hot mirror filter.
This effect is best visible in bright sunlight when IR light is abundant.
Below a picture of my old car with a full-spectrum modified camera and with a IR-pass filter (Hoya R72) in front of the lens,
you see that the rear bumper is darker compared to the rest. On the other hand, it's a mystery why the front bumper doesn't show the same effect.
Old Jan 9, 2021 | 10:40 AM
  #1550
Bill Mack's Avatar
Wow, what a nice picture.
My photo was taken with my iPhone 8 and post-processed using Luminar AI software, but nothing in the area under discussion was modified. Here is the camera information. CabrioBob, you are much more knowledgeable about this than I am, so maybe this will help.
Old Jan 9, 2021 | 10:56 AM
  #1551
Cabrio Bob's Avatar
Bill,
Those numbers tell nothing about IR sensitivity.
You can check it by pointing your iphone to an (old) remote control in a dark room and press a button on the remote. if it lights up on your display, it's sensitive to infrared light.
Don't use those new type of radio-controlled remotes, they don't use IR.
Old Jan 9, 2021 | 01:09 PM
  #1552
Bill Mack's Avatar
Originally Posted by Cabrio Bob
Bill, Those numbers tell nothing about IR sensitivity.
Well I did not know that. Now I do. It was worth a shot, though.
Old Jan 13, 2021 | 11:24 PM
  #1553
gkubrak's Avatar
While I have the intake out for some mods, figured I would upgrade to the Bosch 010 S/C coolant pump, clean all 6 radiators (6... yes 6 lol), and relocate the horn. The intake mod will delete the big ducts at the front, so hopefully all this puts more air through the radiators and lowers temps a bit.
Old Jan 14, 2021 | 01:01 AM
  #1554
AlexJag's Avatar
Sponsor
Good plan!. I bent the horns down, and removed the snorkels as well since so don't need them, although not sure they block much air flow.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Jan 14, 2021 | 08:48 AM
  #1555
gkubrak's Avatar
I feel like they do. Maybe not 'block' but at least prevent some spots from getting nice laminar flow. Those snorkels and the horn have a good amount of area. But will it make a noticeable difference in the end? Probably not!
Old Jan 20, 2021 | 04:25 PM
  #1556
Sean W's Avatar
Looks like my old Schumacher Battery Maintainer has its best years behind it. It's not able to keep the battery charged when the weather dips below freezing. I ordered this one. I didn't want to start another battery tender thread so I hope it dies here. Also got the ring loop connector and extension cable.
Amazon Amazon
Old Jan 20, 2021 | 05:22 PM
  #1557
guy's Avatar
guy
great idea... Ok, I’ll do the same. But I was thinking about replacing the horns with the Fiamm trumpets... what do you guys think?
And the squeak in the climate control fan is at a point where no amount of grease will silence it... guess I’ll bite the bullet and order one of those too.
Old Jan 20, 2021 | 07:09 PM
  #1558
Stuart S's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I hope you read the 1 Star reviews before you decided to buy that NOCO charger. Fortunately, Amazon returns are easy.
There's a reason why CTEK brand battery maintainers are sold by new car dealers as approved accessories with OEM logos. CTEK supplies chargers to the world's most recognized manufacturers including Audi, Bentley, BMW, Camaro, Cadillac, Corvette, Ferrari, Ford, Jaguar, Maserati, McLaren, Mercedes, Porsche, and Rolls-Royce.
https://www.prnewswire.com/news-rele...Rolls%2DRoyce.
Old Jan 22, 2021 | 03:34 PM
  #1559
panthera999's Avatar
'07 XK Base
Replaced a couple of bulbs in the headlight pods. Elated to find that it was a very easy job. 3 bolts and a couple of plugs, and the pod was out. Also, the wiring was in great shape -- my current BMWs have Hellas with rotted wiring.
I only replaced the 2 W5W's with Phillips LEDs 6K, pretty bright. I use these as my daylight driving lights, and needed something more visible than the old markers. Also the 2 D1S', since they were originals and dimming. Used regular Xenon D1S, 4300K color.
Researched LED's for the D1S'. Couldn't find a LED that impressed me, and was the right color, without being overbright and blinding. As to the rest, why bother? Yellow directionals work fine. The cornering lamps do a good job as halogens.
Good engineering on Jag's part.
Old Jan 24, 2021 | 07:55 AM
  #1560
Lord_Eduard's Avatar
Originally Posted by panthera999
'07 XK Base
Try xenarc cool blue intense from Osram. It's xenon, 5500 to 6000K. Looks great.
ThIs is mine with Led DRLs:
