What did you do to your X150 today?
Old Apr 9, 2022 | 05:29 PM
  #1821
Barry Leftwich's Avatar
Originally Posted by mhminnich
Was cleaning the car before my daughter took her out and discovered it had been keyed all up and down the passenger side. I don't get people.
The only answer to that is jealousy and when you that jealous,that's the type of stuff you do that's uncalled for and against the law and it's sad to be stupid enough to do that to people you don't even know.But anyway,how you gone go about fixing it or are you doing an insurance claim?
Old Apr 10, 2022 | 08:02 AM
  #1822
mhminnich's Avatar
Not sure yet. I'm out of town this weekend, but when back I'll take a better look. I was too discouraged at the time to do much more than groan over it. Ironically, the prior xkr i had was pre-keyed when i bought it. Karma.
Old Apr 10, 2022 | 06:15 PM
  #1823
Man that just sounds like deja-vu all over again😮‍💨🤕
Old Apr 10, 2022 | 07:12 PM
  #1824
mhminnich's Avatar
Good news on the keying front. It was actually more like heavy scuffing instead of gouges. I was able to buff out all but a couple of small areas using a polishing pad and finishing compound. Crisis averted.
Old Apr 10, 2022 | 09:03 PM
  #1825
XKRAU's Avatar
Wet weekend last week, it was a good time to get dirty.
Old Apr 11, 2022 | 03:36 PM
  #1826
BagelConsultant's Avatar
Doing my best to fix a couple of busted headlight tabs on the driver's light, damaged and poorly repaired at some point before I owned the car. Plastic welding is ugly but effective so far, need to fine tune the fitment:
Busted tab before
Half the tab is missing here so I'm making the missing piece out of scrap plastic
Plastic-welded back on with steel mesh reinforcement. Needs to be sanded/fine tuned
Headlight removal is super easy
Old Apr 14, 2022 | 09:08 AM
  #1827
Finished fixing up the driver's side headlight tabs, took slightly more revision after the initial repair. Fitment is FAR better than before and the headlight is solidly mounted
Old Apr 17, 2022 | 08:32 AM
  #1828
Lord_Eduard's Avatar
I did some aestethic modifications:
- headlights
- side vents
- front grill
- lip kit
- wheels
In pics bellow you can see 'before and after' changes:
Old Apr 17, 2022 | 09:15 AM
  #1829
Cee Jay's Avatar
I cropped that black matted photo for you:
Old Apr 17, 2022 | 10:36 AM
  #1830
peterv8's Avatar
VERY, VERY NICE!
Where did you buy the sideskirts and front splitter?
Old Apr 17, 2022 | 12:07 PM
  #1831
Originally Posted by peterv8
VERY, VERY NICE!
Tnx. It's just universal one, measure the car and search ebay for appropriate size and shape
Old Apr 23, 2022 | 10:05 PM
  #1832
Tracee's Avatar
New brake pads and rotors on rear. Wasted a lot of time getting the wind-back tool to work; my bad - just not thinking. Interesting thing, and shouldn't be surprised with a used car with 3(?) previous owners, found the rear brake wear sensor hanging loose, but it was incorrect for the rear - was a front wear sensor. Did a previous owner buy the wrong sensor, find out that it didn't fit, so just left it hanging there? Or didn't have the correct one and left it in place so the dash warning light stayed off? The adventures of used cars, and discovering previous "fixes" and making things right...
Old Apr 24, 2022 | 08:51 PM
  #1833
mizzleman's Avatar
Topped off rear diff fluid and added seal conditioner...hopefully that will stop the leak at the left axle shaft.....
Old Apr 26, 2022 | 02:52 PM
  #1834
Sean W's Avatar
Replaced the front lower lateral and forward control arms. I used Eurospare for the banana arms. Still too fricken cold to drive on summer tires. It hasn't hit 40 today so yet to test drive it. She'll need an alignment.
Next is to add CarPlay and Cabrio Bob's ashtray gauge display. Both use the same Cigar lighter feed. My lighter housing is DOA. I've never tried it, but the housing was shot so ordered from Terry's Jaguar and will resume the Cabrio Bob's install when the parts are here. Cambo's CarPlay set up takes advantage of the convenience mode wiring of the Cigar lighter so I'll start working on that in the interim as there are no warm days on the horizon.
Old Apr 26, 2022 | 07:24 PM
  #1835
gctippett's Avatar
Still in the garage
Old Apr 27, 2022 | 04:09 AM
  #1836
guy's Avatar
guy
Be careful @mizzleman ! The fill port on the differential is not the fluid level. I would just empty it and put in the specified amount. The issue is volumetric gain which occurs when the fluid is heated.
The sealant ma work. But the diff gets hot. I think a new seal may be in order.
Old Apr 28, 2022 | 06:54 PM
  #1837
XKRAU's Avatar
I recently did my diff oil on a XKR4.2 and pumping 1.3litres of gear oil that's when the oil started to drip out at the fill hole. Wait till it stops dripping and I capped her off. So the fill hole is the fluid level.
Old Apr 28, 2022 | 07:48 PM
  #1838
steve_k_xk's Avatar
Standard practice ^^^ . Nice one Chris !!
Which brand and oil did you go for
Old Apr 29, 2022 | 07:21 PM
  #1839
V7Sport's Avatar
Added DRL to my 2008 XKR. Using SDD V130 and a Mongoose, set DRL to Canadian spec. Worked like a champ.
CEL indicator came on but cleared after a short drive. Happy camper now!
Old May 5, 2022 | 02:33 AM
  #1840
XKRAU's Avatar
I went with Amsoil 75w-140 severe gear oil.
https://www.amsoil.com/p/severe-gear-75w-140-svo/
Been proven to run cooler without the gear oil breaking down in extreme conditions. It gives me a safety margin especially the way I drive.
Overkill yes, but at least I don't need to worry about it for another 15 years!!
